Discussion: need fast response
Vieux 15/11/2015, 23h05
ilirii
Avatar de ilirii
ilirii is just really niceilirii is just really niceilirii is just really niceilirii is just really niceilirii is just really nice
Envoyé par bahlsen007 Voir le message
Im sorry but i dont have the wiring diagram of the ews module but have you check this :
main*fuse panel: check fuses*9, 22, 27, 29, 30*(ignition switch),*54*(fuel pump), and*14, 49, 67*(EWS).*
Inspect all fuses in the glove compartment if you're dealing with a hard to diagnose no start problem.
-*high amp fuses*above main*fuse panel*(fuseable links).*
There is an 80 amp for the DME and DME main relay, and a*50 amp fuse*for the ignition switch.*
i took all the fuse box looked at the small fuses and big ones u know 40 50 amps that are behind looked at fuses near dde ,in the trunk all good but i cant find the trace where that wire goes thats what iam searching for
ilirii est déconnecté   Réponse avec citation
