Vieux 25/11/2015, 16h01
doud77
Avatar de doud77
doud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant future
salut Nas33, voici la réponde à ta question:
C'est copié/collé du wiki.ross-tech
C'est en anglais mais assez simple pour etre compris une fois digéré pargoogle traduction:
The IMA-ISA values need to be adapted when:
One or more injection valves have been replaced. Make sure not to adjust the valves which have not been changed!
The engine control module has been replaced.
Do NOT adapt these values when you did not replace one of the above parts, also not for training or demonstration purposes.
The adjustment code can be found on the injector itself, it is a 7-digit value and does only use the following chars: 1,2,3,4,5,6,7,8,A,B,C,D,E,F,G,H,K,L,M,N,O,P,R,S,T, U,V,W,X,Y,Z. A value of AAAAAAA is also not valid.
Prerequisites:
Ignition ON
Engine OFF
[Select]
[01 - Engine]
[Adaptation - 10]
Channel 071: IMA-ISA Value for Cylinder 1
Channel 072: IMA-ISA Value for Cylinder 2
Channel 073: IMA-ISA Value for Cylinder 3
Channel 074: IMA-ISA Value for Cylinder 4
Enter the ****** values from each fuel injector as needed.
[Test]
[Save]
[Done, Go Back]
Switch Ignition OFF, wait 10 seconds and switch Ignition ON again. The values should be saved now, please verify them by double checking the adaptation values.
The Test value shows "AAAAAAA" if you have entered an implausible value. If the IMA-ISA value on the new injector is difficult to read, consider scanning the QR code with a smart phone app.
We have had success with BB, Android and iOS platform mobile devices running i-nigma's free app.
doud77 est déconnecté   Réponse avec citation
