Discussion: probleme alim
Vieux 15/12/2015, 11h31
nimbus
Avatar de nimbus
Pouvoir de réputation: 73
nimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond reputenimbus has a reputation beyond repute
SLT ALORS LES TESTE VAN CAR OK PIN6 BSI ALLANT SUR PIN1 BSM OK
PIN 8 BSI ALLANT PIN 5 BSM OK
TESTE DU RELAIS NEGATIF pin 13 du 16v NR noir du bm34 a la masse ETANT DEJA A LA MASSE RAJOUT MASSE
pin14 du 16v GR gris ALIMENTE AVEC OU SANS MASSE
F8 ALIMENTE
F2 NON
JE C PLUS QUOI FAIRE OU PENSER
ES CE BSM VU QUE LE RELAIS CLAQUE PAS SUR 2 BSM DIFFERENT
nimbus est déconnecté   Réponse avec citation
