Vieux 16/12/2015, 09h21
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
@work87,
The reason behind the language problem is two folds and was introduced when Actia decided to change the coding standard in release update 7.74.. I personally don't have this problem as I changed the language manually and described how to do it in another thread.
You could do the following:
Add language "English US" to your Windows and compare your DiagBox language settings with manual language change I posted somewhere on this forum, then tell us if it has helped.
If does not help after you perform the above, I will ask you to check or post few other files.
Simple est déconnecté   Réponse avec citation
