Vieux 18/12/2015, 22h26
scorpium59
Guest
Avatar de scorpium59
Messages: n/a
Voila ce que j'ai pu trouver pour configurer avec le ptt2.1.0 si cela peut t'aider:
1. INSTALL Rheingold SYSTEM AND ITS REQUIREMENT
2. INSTALL INPA SOFTWARE (BMW Standard Tools 2.12) SET PORT FOR USB NUMBER 9
3. INSTALL AVDI COMMON SETUP AND PASSTHRU SETUP/Bosch PASSTHRU
4. INSTALL pttbmw_2.1.0.0 (TO CONNECT AVDI AS PASSTHRU DEVICE )
NOW AFTER INSTALAION COMPLETE DO SOME CONFIGURATION
OPEN START>ALL PROGRAMS>BMWPASSTHRUD2.1.0.0>PASSTHRUD CONFIGURATION.......SELECT YOUR AVDI PT/Bosch PT AND CHECK IN K-LINE BOX AND LAUNCH CONFIG.TOOL
OPEN PROGRAM FILE>BMW AG> PASSTHRUD> TAKE COPY FOR ALL FILES EXCEPT EDIBAS AND PAST IT IN C:\EDIABAS\BIN\ REPLACE ALL FILES WITH SAME NAME .
YOU NEED Ediabas-Konfigurator TO CHANGE FROM STANDARD OBD TO PASSTHRUD JUST OPEN THE LIST AND SELECT PASSTHRUD AND GO ON
NOW AVDI TOOL /Bosch PASSTHRU /READY TO WORK WITH INPA ,NCEXPERT AND WINKFP
START Rheingold SYSTEM AND ACTIVAT IT AND GO TO SITTING ICON SELET VCI CONFIG IN THE LEFT SIDE (INTERFACE TYPE) TAP ON EDIABAS STANDARD SETTING AND END WITH OK
NOW ALL DONE
AND HOPE THIS WILL BE HELPFUL
  Réponse avec citation
