Vieux 07/01/2016, 00h52
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Envoyé par ballajunior Voir le message
Hello Simple,
me again ;-) What about Firmware 4.3.4? Is it from v7.82 up?
Thanks in advance for your feedback.
DiagBox v8.03 introduced Appli.com v4.3.4; (Attached).
DiagBox v8.18 => Firmware = 4.3.4 > PP2000 = 600.76 & Lexia = 500.72 (.NET 3.5 is needed, run as Administrator or XP compatibility).
But since we are at it:
History versions of vci_updater.com :
V1.0.0 (30/03/2013)
- First working version
- Update bootloader to switch the interface to Evolution
- Clear the sector 5 of MCU flash, to erase all traces of the old bootloader
- Erase external SPI EEPROM, and reprogram a random serial number with recognition Peugeot (ACTIA/963830 C/42-07/nnnnnn)
V1.0.1 (31/03/2013)
- On some interfaces SPI EEPROM is not a Winbond but a Spansion, which only supports the delete command 0xC7 against 0xC7 or 0x60 for Winbond -> Using the command 0xC7 instead of 0x60 to be compatible on the two models.
V1.0.2 (31/03/2013)
- The serial number is no longer generated randomly by the firmware but during the firmware customization. So if you share your custom firmware on Internet and it becomes public, the serial number will be quickly blacklisted and your interface will work not anymore with future DiagBox versions
V1.0.3 (13/04/2013)
- Before the upgrade, check if the SPI EEPROM is readable to determine if the interface is compatible or if it's an incompatible interface with simplified hardware. No upgrade occurs in this case to not brick the interface
Type de fichier : rar appli-4.3.4.rar (80,8 Ko, 105 affichages)
Simple est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Simple For This Useful Post:
djalil (01/06/2021), mustaphcl (05/05/2020)
