Vieux 20/01/2016, 02h37
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Update 2, 20 Jan 2016:
I have packaged the Engines (153mb) from DiagBox v8 into the file "DBox_Engns.exe". They are not essential, but I thought I will do that since we are using v8 updates. Link in the attached file.
If someone wishes to try it, be my guest, at your own risk (you can always stop the services delete the new folders and rename the original folders back). If the installer requests overwrite permissions, then you have forgotten to rename the original folders or you are doing it twice. It worked fine on my computer, but it was a quick one without much thought or testing.
Please remember, this software is provided as is; for personal, educational and experimental use to upgrade from DiagBox version 7.82 to 7.83 only. I hold no responsibility for any illegal or improper usage. You install this software at your own risk.
Enjoy, Simple;
Type de fichier : txt DiagBox_7.83_Readme.txt (1,3 Ko, 112 affichages)
Simple est déconnecté   Réponse avec citation
The Following User Says Thank You to Simple For This Useful Post:
yoyomartin2003 (12/11/2017)
