Vieux 26/01/2016, 23h42
ballajunior
Avatar de ballajunior
ballajunior is on a distinguished road
Envoyé par Simple Voir le message
Salam sami, I did not try it on the car, I only installed and ran it. First I will try the 8.02 update (may be sometime next week), I will see what problems do I have and take it one step at a time..
It looks exactly the same as 7.xx but it feels a tiny little bit quicker. In any case, if you replace the Engine with the one I posted yesterday, you already have (more or less) and equal to V8.xx..
On another note, there was someone who suffered from (id0479- M-Not Found).. This happens on VirtualBox installations, because the Appachi service did not start. The solution:
Ensure you have VC++ 2008, it is looking for VC90.CRT" version="9.0.21022.8, but it does not matter you can install the latest..
Then, create a Batch file "DiagBox.bat" on the desktop and write the following inside it..
cd "C:\APP\ddc\opt\apache\bin\"
start httpd_ddc.exe
Cd "C:\AWRoot\bin\launcher\"
start LctPOLUX.exe
This will start the Appachi task, then will fire DiagBox.. I tried it and it works...
Hi Simple,
Hope you are fine?
Any news about your tests on v8.xx? What are the main differences between v7 & v8? What is the reason we are in v7.83, while the original is v8.19? Do you think we could jump and follow the v8 updates in the future? If yes, what will be the added value in term of performance?
Thanks in advance for your feedback.
At one stage, we will need to jump to v8.xx, right?
ballajunior est déconnecté   Réponse avec citation
