Vieux 27/01/2016, 02h52
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Hi ballajunior,
I installed all updates from 8.02 to 8.19, they went fine and the system ran without problems, but I haven't had the chance to test on a car yet. Please notice that all Diagbox updates from 7.67/8.03 are equal.. I think PSA has added connectivity to dealers to obtain data on serviced cars in version 8.
I tried porting the full solution to an another computer (extract without install, thinking of packaging it fully updated) but I had challenges with PC Identifier; Look into "C:\AWRoot\dtwr\cfg\infopds.xml". As I said earlier, I might do a write up on this subject, I need to evaluate the value of the exercise..
If you wish, you could try the complete "C:\APP" folder for DiagBox version 8.19 (includes Lexia and PP2000) already updated (838MB).. it does not include the DiagBox 8.19 "C:\AWRoot" which has the Profile Configuration files, but it should work with your current "C:\AWRoot" setup. It might require the installation of VC++ 2008..
If you notice any operational difference; share the experience.
Try at your own risk...
To try it:
1- Kill all DiagBox services (including sim and FireBird)
2- Rename your current "C:\APP" folder to "C:\APP7"
3- Extract (Here) the App819 to the "C:\" drive and you should have "C:\APP" (make sure you don't have another APP folder inside C:\App\)
4- Restart the computer and try the complete DiagBox 8.19 Engines..
To revert:
1- Just kill all services (including sim and FireBird).
2- Rename the "C:\App" folder to "C:\APP819"
3- Rename "C:\APP7" to "C:\APP"
4- Restart the computer and run DiagBox,
5- If all is well, delete "C:\APP819" or keep it to try whatever you wish at a later stage..
Type de fichier : txt DiagBox_8.19_APP.txt (72 octets, 45 affichages)
Simple est déconnecté   Réponse avec citation
