Vieux 29/01/2016, 10h40
aza
Avatar de aza
Pouvoir de réputation: 32
aza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud ofaza has much to be proud of
salut doud77
le V.I.P Drogo vous a tout fourni la dessus :
la borne 3.46 assure la commande (mise a la masse (GND)) de a bobine du relais principal ,
ce dernier (relais principal),a son tour alimente l' ecu en (12) volts (bornes 1.07, 1.08, 1.08) de l'ecu ; via 2 fusible F1 et F2 !
salutations l'ami
aza est déconnecté   Réponse avec citation
