Vieux 03/02/2016, 14h52
3atman
Avatar de 3atman
Pouvoir de réputation: 22
3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of3atman has much to be proud of
Par défaut Capteur, pression de suralimentation pour MERCEDES-BENZ Vito
OBD Code P0105refers to
The MAP (Manifold Absolute Pressure) sensor is part of the fuel management system. It reacts to changes in engine manifold pressure. The PCM (Powertrain Control Module) monitors the MAP sensor continually to properly run the engine. Changes in engine load require changes in the amount of fuel injected, and timing of the ignition system, etc. An engine under load has more manifold pressure(or less vacuum) than an engine that is coasting. As the load changes, the MAP sensor voltage signal to the PCM changes accordingly. To check the MAP sensor operation, though, the PCM watches other sensors to verify that the MAP sensor is working properly. For example, the PCM compares the TPS (Throttle Position Sensor) signal to the MAP signal to verify the MAP signal isn't "sticking". If the PCM doesn't see a MAP sensor change immediately follow a change in the throttle pedal sensor, it knows there is a problem with the MAP sensor and sets P0105. Or, if the PCM notices that the TPS indicates the engine is under load, but the MAP signal indicates that the engine is "coasting" it, again, knows there is a problem with the MAP sensor or TPS and sets P0105.
Type de fichier : jpg f0261230189.jpg (15,1 Ko, 6 affichages)
Type de fichier : jpg 0905350.jpg (20,4 Ko, 4 affichages)
3atman est déconnecté   Réponse avec citation
