Discussion: DiagBox 8.xx upgrade
Vieux 18/02/2016, 13h03
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Automatically up****** VCI Firmware
To make DiagBox check the VCI firmware and update if necessary,
Precaustion:
Copy or move all files (NOT folders) inside "C:\AWRoot\bin\Launcher\" to a safe location before perfoming the following:
1- Download "Launcher.rar" from the link provided
2- Extract all files into "C:\AWRoot\bin\Launcher\" skipping or replacing existing files (ap.ini need to be replaced)
3- Rename your preferred Firmware inside Launcher folder to APPLI.COM
4- Connect your VCI and wait until it is recognised
5- Launch DiagBox, it will check the VCI Firmware and update ONLY if necessary.
You can disable this function by setting "MAJ_COM=TRUE" to "MAJ_COM=FALSE" in ap.ini
Note: Some users may be afraid that a damaging APPLI.COM may be included in a future update release. It does not matter if this is feasible or not, you can change AP.INI settings to disable firmware update after performing your desired update and put your mind at rest.
Simple..
Type de fichier : txt DiagBox Launcher.txt (619 octets, 93 affichages)
Simple est déconnecté   Réponse avec citation
