Discussion: DiagBox 8.xx upgrade
Vieux 22/02/2016, 22h40
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Reduced process for a fresh DiagBox v8.01 installation:
Installing DiagBox 8.01
1- Install DiagBox 7.01, perform the Activation, this will create the “APPDIAG.SYS”, “CFG.BIN” and “VERSION.INI” files in "C:\AWRoot\bin\fi\" needed for V8.01 installation. Stop the installation (Task Manager, End Task) and reboot the computer.
2- Rename "C:\AWRoot" to "C:\AWRoot7" and uninstall DiagBox v7.01, this will NOT remove “C:\AWRoot7”. Install Microsoft .NET 3.5 SP1, VC++ 2008 and Java and restart the computer.
3- Install 8.01, it will create a new "C:\APP" and "C:\AWRoot" but when requesting User Activation, close it and restart the computer.
4- Run "AWRoot_v7_files_for_v8.exe" (attached to the first post) and restart DiagBox application, it will continue the DiagBox 8.01 installation.
5- When finished, close DiagBox and restart it to ensure it is working fine and no updates are needed, it will report the Version 7.65.
Installing Updates:
1- Download and install "DiagBox_updt_802.ISO" update.
2- Other updates are as explained previously.
Done...
P.S. The order of installing things is important, I had "Data Access Problem" which was sorted by reinstalling Java 7.67 and VC++ 2008 9.0.21022.8, then reinstalling DiagBox 8.01.. a blank "C:\VERSION.TXT" was also added.
Type de fichier : txt VC2k8_Java767_DBox-Files.txt (467 octets, 87 affichages)
Simple est déconnecté   Réponse avec citation
The Following User Says Thank You to Simple For This Useful Post:
doud77 (12/03/2018)
