Bosch 5.3 ABS
Control Module does NOT support Coding
Label File (8E0-614-111-ABS.LBL)
Bosch 5.3 ABS/EDS
Label File (8E0-614-111-EDS.LBL)
Bosch 5.3 ABS/EDS/ASR
Coding
Label File (8E0-614-111-ASR.LBL)
Bosch 5.3 ABS/EDS/ASR/ESP
Login
Coding
si tu n'a pas asr ou esp il n'y a pas de codage
Coding
Coding
000?x: Engine
0 = Gasoline Engine 2.4l-2.8l (without CAN-Databus)
1 = Diesel Engine
2 = Gasoline Engine 1.8T
3 = Gasoline Engine 2.4l-2.8l (with CAN-Databus)
000x?: Transmission
0 = Manual Transmission (012) (without CAN-Databus)
1 = Automatic Transmission (01V) (with CAN-Databus)
2 = Manual Transmission (01E) (with CAN-Databus)
3 = Multitronic (01J) (with CAN-Databus)
3 = Automatic Transmission (01V) (without CAN-Databus)
Login
Note #1: After Login has been carried out you need to Recode the control module then perform the Steering Angle Sensor Calibration. Do NOT exit the Control Module in between the individual steps.
Note #2: For Audi A8 (4D) always use 4 as Selection for Brakes.
Note #3: The Production Codes (PR-Code) such as 1LX can be found on a Sticker near the Spare Tire Well and/or the 1st Page of the Service Manual.
Click here to see an Example of a Sticker.
0?xxx: Chassis
5 = Audi A8 (4D)
7 = Audi A6 (4B)
9 = Audi A4 (8D) / VW Passat (3B)
0x?xx: Brakes
3 = FNRG-60 (Teves/ATE) [PR-1LA/1LG]
4 = FN2/HP2 (Dual-Piston) [PR-1LX] & Brembo [PR-1ZL]
5 = FN3 (Teves/ATE) [PR-1LB/1LE/1LF/1LT/1ZC]
6 = C54 (Lucas) [PR-1LZ]
0xx?x: Engine
5 = 4/6/8 Cyl. Diesel
7 = 4/5 Cyl. Gasoline
9 = 6/8/12 Cyl. Gasoline
0xxx?: Transmission
3 = Manual with Low Range (only Audi A6 Allroad)
5 = Manual
7 = Automatic (01L/01N/01V)
9 = Multitronic (01J)
Coding
Note #1: Coding is accepted after a specific login has been carried out.
Note #2: After successful coding the steering angle sensor basic setting needs to be carried out. Do NOT exit the Control Module in between the individual steps
Note #3: For Audi A8 (4D) always use 3 as Selection for Brakes.
Note #4: The Production Codes (PR-Code) such as 1LX can be found on a Sticker near the Spare Tire Well and/or the 1st Page of the Service Manual. Click here to see an Example of a Sticker.
Note #5: In some cases, you will need to enter a non-zero WorkShop Code, such as 12345-123-12345.
0?xxx: Chassis
4 = Audi A4 (8D) / VW Passat (3B)
6 = Audi A6 (4B)
8 = Audi A8 (4D)
0x?xx: Brakes
1 = C54 (Lucas) [PR-1LZ]
2 = FN3 (Teves/ATE) [PR-1LB/1LE/1LF/1LT/1ZC]
3 = FN2/HP2 (Dual-Piston) [PR-1LX] & Brembo [PR-1ZL]
4 = FNRG-60 (Teves/ATE) [PR-1LA/1LG]
0xx?x: Engine
0xxx?: Transmission
5 = Manual
Dernière modification par jpay2 ; 03/03/2016 à 10h03.
