Discussion: DiagBox 8.xx upgrade
Vieux 03/03/2016, 16h30
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
I tried Google Translation, but I did not understand.. If you are having a problem try this method...
Installing DiagBox 8.01
1- Install DiagBox 7.01 and run update 7.02 then install update 7.xx-7.57 (or any v7.45+ update that creates "C:\AWRoot\dtwr\cfg\Config.sys")
2- Install .NET 3.5 SP1, restart the computer and rename "C:\AWRoot" to "C:\AWRoot7" (you may need to stop some diagBox processes)
3- Run DiagBox 8.01 installation until it requests Activation. Close it and run the tool "AWRoot_v7_Conf+Ativation_v8.exe" it will inject the necessary files and copy the configuration from "C:\AWRoot7".
4- Run DiagBox, it should continue the installation successfully.
AWRoot_v7_Conf+Ativation_v8.exe No password https://mega.nz/#!x8cWWSSI!2Gqp4ma0f...3cLkZSq5Y5klOY
Simple est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to Simple For This Useful Post:
mecadriano (18/11/2017), saadaoui frere (09/12/2018)
