Vieux 22/03/2016, 16h11
omarino
Avatar de omarino
omarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to allomarino is a name known to all
Bonjour les gars
on viens de vérifier le câblage, tous a l'aire bien branchés
quand je passe le vcds voila les codes défauts que j'ai:
Address 01: Engine Labels: Redir Fail!
Part No SW: 4L0 910 401 K HW: 4L0 907 401
Component: 3.0L V6TDI G001AG 0030
Revision: --H03--- Serial number:
Coding: 0011775
Shop #: WSC 80093 222 69422
VCID: 2A5BE423850AF24EEA7-807F
2 Faults Found:
001683 - Can't Decode, CODE File Not Loaded!
P0693 - 001 -
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 179069 km
Time Indication: 0
Date: 2005.09.23
Time: 1855
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 9.9 %
Voltage: 9.96 V
Duty Cycle: 9.9 %
Duty Cycle: 9.9 %
005669 - Can't Decode, CODE File Not Loaded!
P1625 - 011 -
Freeze Frame:
Fault Status: 01101011
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 179069 km
Time Indication: 0
Date: 2005.09.23
Time: 18:39:33
Freeze Frame:
RPM: 0 /min
Torque: 0.0 Nm
Speed: 0.0 km/h
Duty Cycle: 1.0 %
Voltage: 9.65 V
Bin. Bits: 00101000
Torque: -81.6 Nm
Readiness: 0 0 0 1 1
Address 02: Auto Trans Labels: 09D-927-750.lbl
Part No SW: 09D 927 750 DG HW: 09D 927 750 DG
Component: AL 750 6A 0867
Revision: 00H49000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 76E300530132E6AEBEF-8023
1 Fault Found:
01314 - Can't Decode, CODE File Not Loaded!
008 - Can't Decode, CODE File Not Loaded! - MIL ON
Freeze Frame:
Fault Status: 00101101
Fault Priority: 2
Fault Frequency: 5
Reset counter: 0
Time Indication: 0
Date: 2005.10.03
Time: 13:43:00
et plein d'autre erreurs sur les autres adresse que je pense n'impacte pas le démarrage.
j'ai fais un clear de tous-->>> même histoire que la semaine prochaine, la voiture ne veux pas démarrer.
c est vraiment bizarre.
vous avez des idées les gars??
omarino est déconnecté   Réponse avec citation
