Vieux 22/03/2016, 21h31
hugopinho
Avatar de hugopinho
hugopinho is on a distinguished road
Par défaut Clio III alternator problem
Hi friends
I have a problem with a Clio III, 1200 - 16 valves, 2007.
The car had problems with the alternator, it was charging irregularly, causing voltage spikes.
The alternator was repaired and it's OK.
Then, the car sometimes gives me the following error, by Clip:
DF046 (battery voltage)
and by Texa:
P0560
When this error appears, the car begins to fail, it doesn't accelerate.
I have allready checked connectors, contacts, battery, alternator... - everything OK.
I have also tryed with the alternator off, and it appears the same code error.
Could it be a problem with the Ecu?
Siemens SIM32
S120200105 A
820052357
8200510536
Regards and thanks in advanced
HugoPinho
hugopinho est déconnecté   Réponse avec citation
