Pouvoir de réputation: 37
Tu as pleins d'info et d'avis déjà sur le forum a ce sujet...oui très bon outil.
EDC15C3 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 31H - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage
SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code
SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (car runs without immobilizer code)
IAW 6R.20 - Read/Write TMS370 EEPROM
IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code)
VALEO BII for ESPACE III - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement, Read transponder data, Emergency Startup
VALEO IMMOBILIZER for LAGUNA I Ph2 (1998-2000) - Read transponder data, Configure, Reset to VIRGIN
INSTRUMENT CLUSTER for ESPACE III (1998-2002) - Reset odometer, Erase RF remote programming by instrument cluster connector
SIEMENS IMMOBILIZER for ESPACE III Ph1 (1996-1998) - Read/Write 68HC05B16 EEPROM, read transponder data
SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys
LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming, Change VIN
MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming, Change VIN, Reset UCH to VIRGIN
INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check mileage, Change language and units, Change VIN
CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'07) - Read/Write EEPROM 93C66, Key Learning, Change VIN
KANGOO I, TRAFIC, MASTER, VIVARO, MOVANO ('07-) - Key Learning, Change VIN
KANGOO II (2007-2012) - Key Programming, Change VIN
MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code, Change VIN by OBDII
MEGANE/SCENIC III ELECTRIC POWER ASSISTED STEERING (NSK DAE/PAS) - Clear Immo Code, Change VIN by OBDII
LAGUNA III (2007-2015) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
LATITUDE (2010+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
CLIO III / MODUS - Key Programming, Change VIN, Learn ECM in protected mode
CLIO III - Card Programming, Change VIN, Reset UCH to VIRGIN
MASTER III (2010-) - Key Programming, Change VIN
WIND (2010-2013) - Key Programming, Change VIN, Learn ECM
TWINGO II (2007-2013) - Key Programming, Change VIN, Learn ECM
TWINGO (2001-2006), LOGAN (2004-2008), SANDERO I, THALIA, SYMBOL - Key Programming, Change VIN
LOGAN, SANDERO, THALIA, SYMBOL (2008-2012), Duster (2010-2012) - Key Programming, Change VIN
MEGANE III / SCENIC III (2009-2015) - Card Programming, Change VIN, Reset BCM to VIRGIN
