Vieux 01/04/2016, 14h46
RLL
Avatar de RLL
RLL will become famous soon enough
Voici les codes de défauts restant après les avoir effacé et après remise de contact
VCDS Version: Release 12.12.0
Data version: 20130910
Tuesday,01,October,2013,11:43:30:65217
Chassis Type: XX (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 76 7D
VIN: XXXXXXXXXXXXXXXXX Mileage: 129600km/80529miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
7D-Aux. Heat -- Status: OK 0000
Address 01: Engine Labels: 03G-906-016-BKC.lbl
Part No SW: 03G 906 016 CB HW: 028 101 190 0
Component: R4 1,9L EDC G010SG 6176
Revision: 12345678 Serial number: XXXXXXXXXXXXXX
Coding: 0000071
Shop #: WSC 00999 444 64523
VCID: 65CBA9D4AC9F0736075-8030
3 Faults Found:
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 000 -
Freeze Frame:
RPM: 0 /min
Torque: 144.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Temperature: 19.8°C
Temperature: 13.5°C
Temperature: 18.9°C
17075 - Fan 1 Control Circuit
P0691 - 000 - Short to GND
Freeze Frame:
RPM: 0 /min
Torque: 144.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 11.78 V
Bin. Bits: 00001100
Temperature: 13.5°C
Duty Cycle: 9.6 %
17084 - MIL Request from Transm. Control Module (SAE) or Control Module Defective (VAG)
P0700 - 000 - - MIL ON
Freeze Frame:
RPM: 0 /min
Torque: -98.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.69 V
Bin. Bits: 00000000
Bin. Bits: 0
(no units): 0.0
Readiness: 0 0 1 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017025
Shop #: WSC 00046 412 24576
VCID: 3F875BBC6E837DE6AD9-806A
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AF
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6BDFDFEC4A7B3146511-803E
1 Fault Found:
01317 - Control Module in Instrument Cluster (J285)
013 - Check DTC Memory
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 1K0 937 049 M HW: 1K0 937 049 M*
Component: Bordnetz-SG H34 0803
Revision: 00H34000 Serial number: 00000001429045
Coding: E4890F0600041800001400001400000000087B075C
Shop #: WSC 00046 000 409600
VCID: 397335A470A753D693D-806C
Subsystem 1 - Part No: 1K1 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00046
Subsystem 2 - Part No: 1K0 955 559 M Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 005 0605
Coding: 00217125
Shop #: WSC 00046
No fault code found.
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 C HW: 1K0 909 605 C
Component: 07 AIRBAG VW8 013 2100
Revision: 02013000 Serial number: 0033HD06VJ5B
Coding: 0012343
VCID: 2C5D1CF08FF5F67E18B-8079
Subsystem 1 - Serial number: 6332MSME084E121EF
Subsystem 2 - Serial number: 6342MSME083E2639H
Subsystem 3 - Serial number: 6351HSME0646495CD
Subsystem 4 - Serial number: 6361HSME063E48339
1 Fault Found:
01284 - Side Airbag; Drivers Side; Disabled
000 - -
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 F HW: 1K0 953 549 F
Component: Lenksäulenmodul 021 0050
Coding: 0000042
Shop #: WSC 00046 412 598016
VCID: 356B39945CBFB7B6775-8060
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K0 920 861 B
Component: KOMBIINSTRUMENT VDD 0814
Coding: 0003103
Shop #: WSC 80093 222 69422
VCID: 2855E0E09B0DDA5EFC3-807D
1 Fault Found:
00779 - Outside Air Temp Sensor (G17)
010 - Open or Short to Plus
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H09 0110
Revision: 09 Serial number: 27001052041BE7
Coding: 3D3F0F40070002
Shop #: WSC 00046 000 401408
VCID: 2953E5E48007E356E3D-807C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0814
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0153
Coding: 0000052
VCID: 30650880A3DD929E243-8065
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K1 909 144 H
Component: EPS_ZFLS Kl.2 1502
1 Fault Found:
00778 - Steering Angle Sensor (G85)
000 - -
Address 46: Central Conv. Labels: 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 19C802087F2D8404084F01E010CC
Shop #: WSC 06530 995 03754
VCID: 79F3F5A4302793D6D3D-802C
Subsystem 1 - Component: Sounder n.mounted
Subsystem 2 - Component: NGS n.mounted
Subsystem 3 - Component: IRUE n.mounted
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Coding: 0000052
VCID: 31630D84A8D79B962BD-8064
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 L
Component: Radio GR0 012 0018
Revision: 0001201S Serial number: VWZ2Z2E2438748
Coding: 0040400
VCID: 2F670BFCBEE38D663D9-807A
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0213
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
Address 76: Park Assist Labels: 1K0-919-283.lbl
Part No: 1K0 919 283 A
Component: 01 Einparkhilfe 0101
VCID: 2D5B11F4B4EFFF760F5-8078
Address 7D: Aux. Heat Labels: 1K0-963-235.lbl
Part No SW: 1K0 963 235 E HW: 1K0 963 235 E
Component: PTC-Element 0404
Revision: 00800000 Serial number:
End ---------------------------------------------------------------------
Bon week-end
RLL est déconnecté   Réponse avec citation
