Vieux 03/04/2016, 00h31
tony76
Avatar de tony76
Pouvoir de réputation: 29
tony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud oftony76 has much to be proud of
il faut y allez par élimination , controle tes alims , tes masses , et ton reseau can qui va a l'afficheur , il te manque forcement quelque chose !! pour controler ton reseau can il faut etre hors tension si tu as 60 ohms c'est ok si tu 120 ohms ton reseau est ouvert donc apres il faut chercher l
Tony76
tony76 est déconnecté
