Discussion: saxo immo off
Vieux 05/04/2016, 21h45
gkogkolos
Avatar de gkogkolos
gkogkolos has a spectacular aura aboutgkogkolos has a spectacular aura aboutgkogkolos has a spectacular aura about
Envoyé par ajmi_gsm Voir le message
just avec le programme immo killer1.0
tu choisi peugeot 206 et apres tu choisi mangetti marelli la même refference
est c bon
If you do this way with Immokiler I mean, the car will start BUT the 1st temp cooler FAN will NEVER start, only the 2 at big temp will start and this because on 48P2.80 it starts with ECU COMMAND and on the other 48P* versions start through temp valve.
Thats why Immokiller informs you about 1.1i engine ONLY.
Your engine if you use IMMOKILER for 48P2.80 willl be very hot for ever, in the red line because of no 1st cooler fan start.
Check what I mean: http://s21.postimg.org/fg4wvodwn/imm...screenshot.jpg
Better use my solution for NOT having even 1 problem:
http://www.tlemcen-electronic.com/fo...t=33321&page=2
regards
Help to get helped
gkogkolos est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to gkogkolos For This Useful Post:
ajmi_gsm (13/07/2017), mampita (22/08/2018), rico891089 (01/03/2024)
