Vieux 28/04/2016, 16h35
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Old VCI clones with revision B Firmware are blocked by PSA and will not work with DiagBox later than V5.29..
If you cannot upgrade the Firmware to revision C, and you you do not need newer version of DiagBox, then using DiagBox V5.29 or older will solve your problem....
Simple est déconnecté   Réponse avec citation
