Vieux 21/05/2016, 19h06
danyparis
Avatar de danyparis
Pouvoir de réputation: 27
danyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud ofdanyparis has much to be proud of
J'ai effectué un SCAN des valeurs concernant le FAP
J'obtiens
CANAL 67
Temp avant FAP 152,4°
Temp dans FAP 122,5°
Press diff 0,0 mbar
Press diff offset 1 mbar
CANAL 68
FAP load coeff 20%
FAP carbon mass 58,12
Carbon mass learned value -18,6%
CANAL 69
Status 1 regeneration 00000000
Status 4 regeneration 00000000
CANAL 70
Regeneration 0,0 scd
Failed regeneration 0,0
Success regeneration 0,0
Canal 71
Engine speed 798 tr/mn
Quantite injection 0,0 mg/tps
Injection start (post injection) 44° ApPMH
Duree injection (post injection) 0,0° kw
A savoir que le moteur varie entre 800 et 1000 tr/min
Quand il passe a 1000 tr/min j'ai des ratés et la fumée commence
Voila
ZA KRALJA I OTADZBINU, SLOBODA ILI SMRT
danyparis est déconnecté   Réponse avec citation
