Vieux 08/09/2011, 22h46
goldorak
Avatar de goldorak
goldorak is just really nicegoldorak is just really nicegoldorak is just really nicegoldorak is just really nice
Envoyé par laurentis Voir le message
martech ne lit pas l'atmega
il faudra lire avec un programmateur externe
le Martech peut decoder le zenec ze-mc2000 depuis longtemps.
en voici la preuve:
RCDPRO 0.0.4.8 - Zenec MC2000 in support
2011-03-26
Rcdpro 0.0.4.8 - Zenec 2000 in support
Latest Update:
- Zenec, ZE-MC2000
- Matsushita, CQ-VD550W3 DVD
MC2000 decoding goes via reading original dump from processor. Details inside Rcdpro.
Other changes:
- New CLIP Firmware : 02.00.00.03 (automatic update after launch, do not interrupt)
- Added support for SPI and Microwire Memory in Box 2 Plus, and CLIP (Read & Write modes for 8 / 16 bit)
- Added support for SPI serial flash memory (25FL128)
- The ability to read through the interface 4-wires and 3-wires (schematics stored in Programmer bookmark)
- Detection of connected memory for Microwire
- Added ability to put direct links into tool
- Swap Buf. - additional button to swap memory in Dump mode (after use the program again executes the code reading algorithm, this time for inverted bytes)
- Direct Mode is parametrized by Bus speed and Device address
- Added information about the differences in file size, Rcdpro informs what is to be valid
- Added connection diagrams for new protocols directly in the tool
- Programmer tab will store all the possible protocols supported by Clip
- Main menu improvement (works more stable and faster)
- The program remembers the chosen model, you don't need to choose again if dump is bad
- Added option to reload the file from the dump
- Scrollbar in the main menu works as it should and does not move into the void
goldorak est déconnecté
