Vieux 11/07/2016, 18h29
abou
Avatar de abou
abou will become famous soon enough
Je rajoute les captures ecran. ceux qui est bizarre est qu'au diag l'ecu est bloqué par l'immo mais pas de voyant clef orange au tableau de bord...
ci dessous le rapport de diag au vcds:
Tuesday,01,October,2013,1710:30835
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 1J - VW Golf/Bora IV
Scan: 01 02 03 08 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57 75
76
Mileage: 163980km/101892miles
Address 01: Engine Labels: Redir Fail!
Part No: 036 906 034 BH
Component: MARELLI 4MV 5165
Coding: 00031
Shop #: WSC 00000
VCID: 59B97B8DC302531
1 Fault Found:
17978 - Engine Start Blocked by Immobilizer
P1570 - 35-00 -
Readiness: 1110 0101
Address 03: ABS Brakes Labels: 1C0-907-37x-ABS.lbl
Part No: 1C0 907 379 C
Component: ABS FRONT MK60 0103
Coding: 0001025
Shop #: WSC 31414 000 00000
VCID: 2A5BF44186E4089
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Address 15: Airbags Labels: 6Q0-909-605-VW5.lbl
Part No: 6Q0 909 605 A
Component: 0F AIRBAG VW5 01 0004
Coding: 12358
Shop #: WSC 31414
VCID: 3561D73D0F5A571
No fault code found.
Address 17: Instruments Labels: 1J0-920-xx5-17.lbl
Part No: 1J0 920 825 A
Component: KOMBI+WEGFAHRS. BOO V04
Coding: 01113
Shop #: WSC 04437
VCID: 26430071C2FC2C9
Subsystem 1 - Part No: Ident
Component: Nr. WEGFAHRS.:VWZ6Z0Y2093079
Ident.-Nr. WEGFAHRS.:VWZ6Z0Y2093079
Address 19: CAN Gateway Labels: 6N0-909-901-19.lbl
Part No: 6N0 909 901
Component: Gateway KCAN 0001
Coding: 00006
Shop #: WSC 31414
VCID: F0EFA629B0B8B29
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AH
Component: 4E Zentral-SG Komf. 0001
Coding: 04097
Shop #: WSC 31414
VCID: 8407FAF99400BE9
Subsystem 1 - Part No: 1J1959801C
Component: 4E Tõrsteuerger. FS0002
Subsystem 2 - Part No: 1J1959802D
Component: 4E Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 4E Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 4E Tõrsteuerger. HR0002r
End ---------------------------------------------------------------------
Address 01: DTCs cleared
Envoyé de mon SM-J500FN en utilisant Tapatalk
:10: rien de tel que de bon forum pour mieux s'informer et progresser. . .
abou est déconnecté   Réponse avec citation
