Vieux 20/07/2016, 19h20
raed83300
Avatar de raed83300
Pouvoir de réputation: 37
raed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond reputeraed83300 has a reputation beyond repute
Salut l'ami si tu es pas équipé pour swap eeprom
Oubli le swap tu ouvre le calculateur tu le branche sur la voiture tu met le contact pin 24 du flash à la masse 10 secondes Tu enleves le fil de masse sans couper le contact injecté ton ori on obd
Si je t'apporte mon aide n'oubli pas le bouton thanks
raed83300 est déconnecté   Réponse avec citation
The Following 2 Users Say Thank You to raed83300 For This Useful Post:
hmicco (20/07/2016), prinzo57 (20/07/2016)
