Vieux 23/07/2016, 17h26
Coffin_Rider
Avatar de Coffin_Rider
Coffin_Rider will become famous soon enough
Pour info voici le diag:
hursday,24,March,2016,07:3953046
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.2.0 (x64)
Data version: 20150311
www.Ross-Tech.com
VIN: xxxxxxxxxxxxxxxxxx License Plate:
Mileage: 149680km-93006mi Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 07 08 09 0E 10 14 15 16 17 19 1B 20 22 36 37 42
46 47 52 53 55 56 62 6D 72 77
VIN: xxxxxxxxxxx Mileage: 149680km-93006miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1B-Active Steering -- Status: OK 0000
20-High Beam Assist. -- Status: OK 0000
22-AWD -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
6D-Trunk Elect. -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine (J623-CAKA) Labels: 06E-907-551-CAK.clb
Part No SW: 8K0 907 551 HW: 8K0 907 551
Component: 3.0T SIMOS84 H01 0004
Revision: --------
Coding: 010C000C240F0128
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM30TFS8K0907551 A01006
ROD: EV_ECM30TFS8K0907551.rod
VCID: 6ED5B87FB15833518C3-803B
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 8K0 927 156 H HW: 0B5 927 156 D
Component: 0B5 30TFSIRdW H02 0009
Revision: --H02--- Serial number: 0000000097
Coding: 000001
ASAM Dataset: EV_TCMDL501 A02044
ROD: EV_TCMDL501.rod
VCID: 397F5B23B896A4E9691-806C
Address 03: ABS Brakes (J104) Labels: 8K0-907-379.clb
Part No SW: 8K0 907 379 AJ HW: 8K0 907 379 AJ
Component: ESP8 quattro H04 0040
Revision: -------- Serial number: --------------
Coding: 296D02
Shop #: WSC 06342 000 00000
VCID: 010FF3C398C63C29611-8054
1 Fault Found
02214 - Tire Pressure Warning
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 33
Mileage: 149676 km
Time Indication: 0
Date: 2016.03.22
Time: 13:38:36
Freeze Frame:
Hex Value: 0x3400
Hex Value: 0x4006
Hex Value: 0x1235
Hex Value: 0x0EB6
Hex Value: 0x00FF
Address 05: Acc/Start Auth. Labels: None
VCID: 55A7F793BCCE60896D9-8000
No Faults Found
or DTCs not supported by controller
or a communication error occurred
Address 07: Control Head Labels: Redir Fail!
Part No SW: 8T0 035 729 T HW: 4E0 035 729
Component: Interfacebox H43 5570
Revision: 00000000 Serial number: 329AN097634133
Coding: 0001006
VCID: 4A9D14EF25703F71F0B-801F
Subsystem 1 - Part No: 8T0 919 609
Component: E0380 BedienteilH08 0100
Subsystem 2 - Serial number: 00000000648051
Subsystem 3 - Serial number: 0126.09.100000000100010371ÿ
Subsystem 4 - Serial number: 010371ÿ
Address 08: Auto HVAC (J255) Labels: Redir Fail!
Part No SW: 8T1 820 043 AC HW: 8T1 820 043 AC
Component: KLIMA 3 ZONEN H06 0150
Revision: C1000000 Serial number: 01280120090939
Coding: 66000000
VCID: 72EDAC0FAD6017B168B-8027
Address 09: Cent. Elect. (J519) Labels: 8K0-907-063.clb
Part No SW: 8K0 907 063 D HW: 8K0 907 063 D
Component: BCM1 1.0 H22 0253
Revision: 05022001 Serial number: 00000000309643
Coding: 260050914074AF313F01000300001D0D0F9CC7480001014100 0000
VCID: 3069660763EC65A1DEF-8065
Subsystem 1 - Part No SW: 8K1 955 119 A HW: 8T1 955 119 Labels: 1KX-955-119.CLB
Component: WWS 210109 H06 0070
Coding: 00FD11
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Coding: 025028
Subsystem 3 - Part No SW: 8K0 941 531 AA HW: 8K0 941 531 AA
Component: E1 - LDS H07 0080
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 8T1 035 110 C HW: 8T1 035 110 C
Component: MP3-Changer H43 0390
Revision: 00043003 Serial number: AUZ5ZBI8730820
Shop #: WSC 00000 000 00000
VCID: 2A5D746F85301F7110B-807F
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 G HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0040
Revision: 11001001 Serial number: 40040902606704
Coding: 10010D
VCID: 3D774F33A4BE98C9459-8068
Address 14: Susp. Elect. (J250) Labels: None
Part No SW: 8K0 907 364 A HW: 8K0 907 364
Component: DAEMPFUNGS-SG H08 0050
Revision: 00000000 Serial number: 20010900300002
Coding: 050181
VCID: 316F630368E66CA9D11-8064
Address 15: Airbags (J234) Labels: 8K0-959-655.clb
Part No SW: 8K0 959 655 B HW: 8K0 959 655 B
Component: AirbagVW-AU10 H27 0410
Serial number: 0038JD1DSUJ5
Coding: 30343435363030303030554A304C384B3053
ASAM Dataset: EV_AirbaECUVWAUDI010 A02007
ROD: EV_AirbaECUVWAUDI010_AU48.rod
VCID: 3C714237B7A491C1727-8069
Crash sensor for side airbag; driver side:
Serial number: 6334MSME45334648A
Crash sensor for side airbag; front passenger side:
Serial number: 6344MSME45327549D
Crash sensor for side airbag; rear; driver side:
Serial number: 6352QSME051629123
Crash sensor for side airbag; rear; passenger side:
Serial number: 6362QSME1E202D3CP
Crash sensor for front airbag; driver side:
Serial number: 63732SME42202D0E-
Crash sensor for front airbag; front passenger side:
Serial number: 63832SME42204028M
Address 16: Steering wheel (J527) Labels: 8K0-953-568.clb
Part No SW: 8K0 953 568 G HW: 8K0 953 568 G
Component: Lenks.Modul H13 0013
Revision: -------- Serial number: 90315IAL00075
Coding: 000037
VCID: 3E75483FA9B883D15C3-806B
Component: E221 - MFL H02 0003
Address 17: Instruments (J285) Labels: 8T0-920-xxx-17.clb
Part No SW: 8K0 920 930 E HW: 8K0 920 930 E
Component: KOMBIINSTR. H03 0224
Revision: 00000000 Serial number: 9E425MG19
Coding: 0F071100B3000008030000
VCID: 2F6B657B7ED27A59C75-807A
Address 19: CAN Gateway (J533) Labels: 8T0-907-468.clb
Part No SW: 8T0 907 468 Q HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0095
Revision: FB600048 Serial number: 4800F0912180DC
Coding: 000303
VCID: 4FAB05FB1E121A59A75-801A
Subsystem 1 - Part No SW: 8K0 915 181 B HW: 8K0 915 181 B
Component: J367-BDM H04 0150
1 Fault Found
03041 - Energy Management Active
Freeze Frame:
Fault Priority: 7
Fault Frequency: 254
Reset counter: 36
Mileage: 146544 km
Time Indication: 0
Date: 2015.09.18
Time: 1900
Address 1B: Active Steering (J792) Labels: None
Part No SW: 8K0 907 144 C HW: 8K0 907 144 C
Component: DYNAMIKLENK. H06 0500
Revision: 50001005 Serial number: --------------
Coding: 8C0000
Shop #: WSC 06334 000 00000
Address 20: High Beam Assist. (J844) Labels: 8K0-857-511.clb
Part No SW: 8K0 857 511 E HW: 8K0 857 511 A
Component: FLA H04 0004
Revision: AA001002
Coding: 040182646E6E645A5A253D3E
Shop #: WSC 47248 000 1048576
VCID: 3363690B92FA5EB9A3D-8066
Address 22: AWD (J492) Labels: 8K0-907-163.clb
Part No SW: 8K0 907 163 HW: 8K0 907 163
Component: 4 Wheel Drive H09 0004
Serial number: 001112080001010
ASAM Dataset: EV_AllWheelDiffeQSPCAN 003007
ROD: EV_AllWheelDiffeQSPCAN.rod
VCID: 6DD7BF73BC5EC849B59-8038
Address 36: Seat Mem. Drvr (J136) Labels: 8T0-959-760.clb
Part No SW: 8K0 959 760 HW: 8K0 959 760
Component: MEM-FS H05 0043
Revision: AA000000 Serial number: 00001001207139
Coding: 00581300000000000000
VCID: 77FB9D1BC60272995F5-8022
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 M
Component: MNS ECE H52 1060
Revision: 00000000 Serial number: 333AO097643139
Shop #: WSC 03130 995 90038
VCID: 3B73412B7AAA96F97BD-806E
Address 42: Door Elect, Driver (J386) Labels: 8K0-959-793.clb
Part No SW: 8K0 959 793 D HW: 8K0 959 793 D
Component: TSG FA H11 0250
Revision: Serial number: 0000008405549
Coding: 011C02205E00410001
VCID: 418F33C3D846FC29211-8014
Address 46: Central Conv. (J393) Labels: 8K0-907-064-46.clb
Part No SW: 8K0 907 064 BQ HW: 8K0 907 064 BQ
Component: BCM2 1.1 H90 0247
Revision: 00002001 Serial number: 0116851250
Coding: 013A0620203934940030020000000000
VCID: 0009F6C793CC35216EF-8055
Subsystem 1 - Part No: 8K0 951 177
Component: DWA-Sensor H02 0040
Subsystem 2 - Part No: 1K0 951 605 C
Component: LIN BACKUP HO H03 1301
Subsystem 3 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J245 PS130 H06 0037
Subsystem 4 - Part No SW: 8K0 959 591 HW: 8K0 959 591
Component: J394 PS225 H06 0037
2 Faults Found
02616 - Fuel Tank Cap; Unlock
009 - Open or Short to Ground
Freeze Frame:
Fault Status: 01101001
Fault Priority: 2
Fault Frequency: 104
Reset counter: 5
Mileage: 134482 km
Time Indication: 0
Date: 2014.01.08
Time: 11:49:32
02615 - Fuel Tank Cap; Lock
Freeze Frame:
Fault Priority: 2
Fault Frequency: 109
Reset counter: 216
Mileage: 137483 km
Time Indication: 0
Date: 2014.10.13
Time: 0933
Address 47: Sound System (J525) Labels: Redir Fail!
Part No SW: 8T0 035 223 T HW: 8T0 035 223 F
Component: DSP Prem H14 0400
Revision: 00H14003 Serial number: 34814005083601
Coding: 020101
Shop #: WSC 12336 024 394758
VCID: 3F8B353BAEB28AD9575-806A
Address 52: Door Elect, Pass. (J387) Labels: 8K0-959-792.clb
Part No SW: 8K0 959 792 D HW: 8K0 959 792 D
Component: TSG BF H11 0250
Revision: Serial number: 0000008410375
VCID: 408936C7D34CF5212EF-8015
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 F HW: 8K0 907 801 F
Component: EPB Audi B8 H06 0070
Revision: 00000003 Serial number: 10000000174850
VCID: 326D6C0F6DE057B1A8B-8067
Address 55: Headlight Range Labels: 8K0-907-357.clb
Part No: 8K0 907 357 B
Component: Dynamische LWR H01 0030
Revision: 00000001 Serial number:
Coding: 0000005
VCID: 34616A1757F45981BA7-8061
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4F0 035 541 N
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 357AJ097520017
Coding: 0000001
VCID: 316F6303A8E66CA9D11-8064
Address 62: Door, Rear Left (J388) Labels: 4F0-959-795.clb
Part No SW: 4F0 959 795 N HW: 8K0 959 795 C
Component: TSG HL H10 0251
Revision: Serial number: 0000008385692
Coding: 010C02204000210001
VCID: 44813AD7C754E9010A7-8011
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8K9 827 851 HW: 8K9 827 851
Component: J605 Master H27 0280
Revision: -------- Serial number: 8K9827851
VCID: 7BF3812BFA2A56F93BD-802E
Subsystem 1 - Part No SW: 8K9 827 852 HW: 8K9 827 852
Component: J756 Slave H27 0280
1 Fault Found
16347 - Control Module - EEPROM Error
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 122
Mileage: 133816 km
Time Indication: 0
Date: 2013.12.10
Time: 1701
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H10 0251
Revision: Serial number: 0000008385597
Address 77: Telephone Labels: 4F1-910-336.lbl
Part No SW: 4F1 910 336 D HW: 4F1 862 335
Component: BTA H12 1120
Revision: 00H12000 Serial number: 00000007521476
Coding: 0020031
VCID: 25478753EC2E30093D9-8070
End-------------------------(Elapsed Time: 07:59)--------------------------
Coffin_Rider est déconnecté   Réponse avec citation
