Discussion: toyota rav4 d4d 2010
Vieux 17/08/2016, 11h14
Tidus97
Avatar de Tidus97
Pouvoir de réputation: 36
Tidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond reputeTidus97 has a reputation beyond repute
slt! c pas le calculo qu'il faut ouvrir là. Voici la description de ton defaut:
DTC C1280/82 Engine Circuit Malfunction
DTC No. DTC Detection Condition Trouble Area
C1280/82 When the following continues for 5 seconds
or more:
- Communication with engine control ECU is
operating normally, but throttle position
sensor is malfunctioning.
• Throttle position sensor
• Throttle position sensor wire harness and
connector
• CAN communication system
A vérifier donc ton potentiomètre accélérateur.
Souvent sur rav4, j'ai plutôt une défaillance sur le contacteur de frein (double piste) qui génère le même type de voyant.
Tidus97 est déconnecté   Réponse avec citation
