Discussion: Winols 2.24
Vieux 29/08/2016, 09h12
Kennfeld
Avatar de Kennfeld
Pouvoir de réputation: 26
Kennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud of
Winols supporte désormais d'autre émulateurs que ols300 et ols200
Errors / Changed Items:
* Changed Items Version Date
Fixed Crash after loading a project on some PCs 3.67 24.08.2016
Important! Simulator changed: Its now in the DLL OLS1007 which is free for all OLS200/OLS300 customers. 3.66 23.08.2016
Important! Simulator improved: Now a new option for realtime binary file export for processing in third party programs 3.66 23.08.2016
New Drivers updated 3.66 23.08.2016
New Loading / saving large projects is slightly faster 3.66 23.08.2016
New progress display while saving 3.66 23.08.2016
New Import: Automatic project comment now optional (F12 > Import) 3.66 23.08.2016
New OpenProject: New checkbox for not saving the changed sorting order 3.66 23.08.2016
New Rightclick on folder potential maps now includes delete function 3.66 23.08.2016
New Reseller: Three new data fields are uploaded (EcuNrProd, Software, SoftwareVersion) 3.66 23.08.2016
New ImportWiz: Bei entpackten Dateien beide Dateinamen für die Projekteigenschaften auswerten 3.66 23.08.2016
Fixed 2d: When scrolling horizontally by dragging in the scale the cursor wasnt updated 3.66 23.08.2016
Fixed Csv-Export exported X-DataOrg incorrectly 3.66 23.08.2016
Fixed EcuX-Import with multiple versions: Only the original was imported 3.66 23.08.2016
Fixed Pasting as delta didnt work properly when the result was negativ and not float 3.66 23.08.2016
Fixed Vehicle type wasnt correctly deduced from the filename 3.66 23.08.2016
Fixed Importing a smaller version could lead to crashes or no import at all 3.66 23.08.2016
Fixed Connect: Transferring values as delta/percent used the original (instead of version) as base 3.66 23.08.2016
Fixed ImportWiz: zip with multiple files: Finish immediately didnt work in the file selection page 3.66 23.08.2016
Fixed ImportWiz: Importing version names with path didnt work 3.66 23.08.2016
Fixed ImportWiz: Graphics error for ComboBox on Similar-Page 3.66 23.08.2016
New Driver updates 3.65 03.08.2016
Fixed Mistake on HiLo import for some files 3.65 03.08.2016
Fixed HiLo-Export with zip created unneeded file 3.65 03.08.2016
Fixed Missing precision when inserting a delta clipboard into a float hexdump 3.65 03.08.2016
New Map list: More useful display of start address for hexdumps 3.64 12.07.2016
New Connect bar: Updates now scrollbar when offset is changed 3.64 12.07.2016
Fixed n didnt always work for connected projects with offset 3.64 12.07.2016
Fixed Crash in PrjProperties > Search more when project still empty or during import 3.64 12.07.2016
Fixed Crash/Graphics error when comment started before 2d-invers-map and overlapped with the map 3.64 12.07.2016
Fixed EditAsText used a wrong address when editing 3.64 12.07.2016
Fixed ImportWiz: Crash after right-click in file list 3.64 12.07.2016
Kennfeld est déconnecté   Réponse avec citation
