Vieux 15/09/2016, 10h58
rushx13
Avatar de rushx13
rushx13 will become famous soon enoughrushx13 will become famous soon enough
voila ce que dit le site
Features
RomRaider provides many features normally only seen in commercial software applications. The main capabilities are:
Platform agnostic: RomRaider is written in Java making it easier to support tuning on various operating systems. Currently Windows and Linux are supported.
Subaru support: Support for many Subaru ROM versions via plug-in ECU definition data files. ECU definitions can be upgraded independently of the ****** tuning software.
BMW support: Support for 1996–2003 versions of BMW DME (MS41/42/43 variants) via plug-in DME definition data files. DME definitions can be upgraded independently of the ****** tuning software.
Multiple maps: The ability to load, modify and save one or more ROM files
Intuitive user interface: Simple, easy to use user interface which presents the various ROM maps within a tree view grouped by function e.g. Boost, Fuel, Timing are each groups collating a number of related maps.
Tuning by User Level: This is a tuning safety related capability which restricts (write) access to certain maps based on User Level e.g. beginner, intermediate, advanced. User level may be dynamically switched at any time.
Intelligent map data display: All data within maps are intelligently displayed using the appropriate unit of measure e.g. RPM, Boost (PSI/Bar - absolute or relative), Temperature (degrees F or C). Additionally map data is colour coded greatly reducing the time taken to understand and tune a map.
3D graphing: Map table data may be displayed in 3D as an additional map visualisation aid.
Map tuning assistant: A detailed description of each map is available to the tuner from the map properties page.
Map comparison: This allows maps from the same or different ECUs to be easily compared.
Map copy & paste: ROMs can be quickly tuned using the map copy and paste capability.
Map smoothing: This allows tuners to interpolate map data values greatly reducing the time taken to alter maps.
Realtime data logging and post analysis tool: This includes the ability to overlay data logs on to ****** maps as an aid when fine tuning.
http://www.romraider.com/RomRaider/Features
pour ceux qui veulent en connaitre plus.
pas de thanks ,pas d'aide .
Il y a un minimum de politesse que certains n'ont pas visiblement.
rushx13 est déconnecté   Réponse avec citation
