Vieux 18/09/2016, 18h34
angels59
Avatar de angels59
Pouvoir de réputation: 66
Envoyé par repcles Voir le message
bonjour a tous , vous en servez pourquoi le renault ecu tool, est il facile d utilisation,merci du retour .
bonjour repcles
Une petite recherche sur google et voilà tout ce que peut faire Renault ecu tool ;)
Pour l'utilisation ça ne doit pas être trop complexe!!!
Renault CAN/K-line ECU Tool
OBDII tool with various Renault car electronic control unit internal memory modification functions, such as Read/Write EEPROM or FLASH, Clear Immobilizer Code, Read Immobilizer Status and Program Cards. There is no need to open control unit, de-solder memory IC or connect any wires directly to it. All functions works by OBDII connector, but any supported control unit can be connected "on the bench" using Connection Manual. Clear Immobilizer Code function is fully automated - just press button and control unit will be cleared. ECU is ready to accept new immobilizer code after previously programmed code is cleared - no future programming is required.
Download: [Software] [User Manual] [Connection Manual]
Software V2.49 supports:
EDC15C3 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EDC15C13 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 31H - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 32[N] (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 34 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SIRIUS 35 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3132 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
EMS3134 (both CAN-BUS and WIRE immo systems) - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code
SID301 - Read/Write EEPROM, Read/Write FLASH, Clear Immo Code, Clear IMPACT DETECTED, Read stored mileage
SIM32 - Read/Write EEPROM, Read/Write FLASH from HD64F7055, Clear Immo Code
SAFIR / SAFIR2 / SFR200 (35 / 55 pin connector) - Read TMS374 EEPROM, Clear Immo Code (car runs without immobilizer code)
IAW 6R.20 - Read/Write TMS370 EEPROM
IAW 6R.30 - Read TMS370 EEPROM, Clear Immo Code (car runs without immobilizer code)
VALEO BII for ESPACE III - Read/Write (9)08AZ60 EEPROM, Read/Write mileage, Clear for Replacement, Read transponder data, Emergency Startup
VALEO IMMOBILIZER for LAGUNA I Ph2 (1998-2000) - Read transponder data, Configure, Reset to VIRGIN
INSTRUMENT CLUSTER for ESPACE III (1998-2002) - Reset odometer, Erase RF remote programming by instrument cluster connector
SIEMENS IMMOBILIZER for ESPACE III Ph1 (1996-1998) - Read/Write 68HC05B16 EEPROM, read transponder data
SIEMENS UCH for MEGANE/SCENIC ('98-'02) - Read/Write 705B32 EEPROM, Read/Write configuration, Learn Keys
LAGUNA II, ESPACE IV, VELSATIS, LAGUNA II Ph2, ESPACE IV Ph2, VELSATIS Ph2 - KeyCard Programming, Change VIN
MEGANE II, SCENIC II, MEGANE II Ph2, SCENIC II Ph2 - KeyCard Programming, Change VIN, Reset UCH to VIRGIN
INSTRUMENT CLUSTER for SCENIC II ('04-'08) - Wake-Up by CAN-BUS for repair or to check mileage, Change language and units, Change VIN
CLIO II Ph2, KANGOO, TRAFIC, MASTER, VIVARO, MOVANO (-'07) - Read/Write EEPROM 93C66, Key Learning, Change VIN
KANGOO I, TRAFIC, MASTER, VIVARO, MOVANO ('07-) - Key Learning, Change VIN
KANGOO II (2007-2012) - Key Programming, Change VIN
MODUS / CLIO III ELECTRIC POWER ASSISTED STEERING (TRW DAE/PAS) - Clear Immo Code, Change VIN by OBDII
MEGANE/SCENIC III ELECTRIC POWER ASSISTED STEERING (NSK DAE/PAS) - Clear Immo Code, Change VIN by OBDII
LAGUNA III (2007-2015) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
LATITUDE (2010+) - KeyCard Programming, Change VIN, Reset BCM to VIRGIN
CLIO III / MODUS - Key Programming, Change VIN, Learn ECM in protected mode
CLIO III - Card Programming, Change VIN, Reset UCH to VIRGIN
MASTER III (2010-) - Key Programming, Change VIN
WIND (2010-2013) - Key Programming, Change VIN, Learn ECM
TWINGO II (2007-2013) - Key Programming, Change VIN, Learn ECM
TWINGO (2001-2006), LOGAN (2004-2008), SANDERO I, THALIA, SYMBOL - Key Programming, Change VIN
LOGAN, SANDERO, THALIA, SYMBOL (2008-2012), Duster (2010-2012) - Key Programming, Change VIN
MEGANE III / SCENIC III (2009-2015) - Card Programming, Change VIN, Reset BCM to VIRGIN
cdlt
