Vieux 04/11/2016, 11h49
doud77
Avatar de doud77
doud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant futuredoud77 has a brilliant future
SAlut,
voici la procédure pour all keys lost dans ton cas, procedure vcds.
Procedure for all keys lost is different.
Here you go:
Have hazards all time on and Press brake pedal for more then 30 sec.
Go to 25 Immobilizer
Login with pin. ( Ex 44234)
Cluster will show Immobilize Adjustment Active.
Wait till says Immobilizer Active
Got to adaptation ch 50 and in in new value put same pin as car has .( Ex 44234)
[Test]
In Upper left corner you will see VIN number of the car ,
DO NOT click [Save] WAIT till steering lock in unlocked and cluster will light up.
After steering lock in unlocked and cluster will light up.
Click [Save]
Go out of adaptation but DO NOT go out of the controller.
Login again with pin (Ex 44234)
Go to Adaptation CH 01 and put 01 in new value ( for one key)
[Test]
[Save]
Go out of the controller.
Take out key and put it back
Cluster will show in lower right corner 1-1
Take out the key again and put it back and start car.
doud77 est déconnecté   Réponse avec citation
