Vieux 05/11/2016, 20h55
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut Error "psaAagent.exe" on VirtualBox
If you are getting "psaAagent.exe" error or missing DiagBox tabs on VirtualBox, then entering a System Serial for the Virtual Machine (as described below) and installing VC++ 2008 resolves it.
- Start an Administrator's CMD and navigate to "C:\Program Files\Oracle\VirtualBox\", and execute the following command (Replacing "Your VM" with your Virtual Machine's name, and System Serial with your hardware's, like "CDN29326BH", any other code may also work):
C:\Program Files\Oracle\VirtualBox>VBoxManage setextradata "Your VM" "VBoxInternal/Devices/pcbios/0/Config/DmiSystemSerial" "System Serial"
Simple.
Simple est déconnecté   Réponse avec citation
The Following 5 Users Say Thank You to Simple For This Useful Post:
colas (15/05/2020), DrDG (05/11/2016), Geri (25/08/2017), Guiiix (14/08/2021), jojolabricole (24/11/2016)
