Vieux 08/11/2016, 23h19
terminator1000
Banned
Avatar de terminator1000
terminator1000 is a name known to allterminator1000 is a name known to allterminator1000 is a name known to allterminator1000 is a name known to allterminator1000 is a name known to allterminator1000 is a name known to all
Envoyé par san-style95 Voir le message
Un peut radicale comme solution lol .
Oui j ai bien inserer la clé . Elle est reconnue dans le gestionaire de perifh mais tjr le meme message d erreur
Envoyé de mon SM-G900F en utilisant Tapatalk
T'as acheter ca ou ?
as tu installer touts les crack comme indiqué ? si oui / ton dongle est HS
close your pc anti-software first,very important.
1. first- install the"fordupdate1.1.1",second- install the "truecodesetup"
2.copy the content of folder "ford crack" to the installed patch : C:XXX TrueCode ,replace the old files.,then run the FordOBD.exe,the ford software is OK now.
3.copy the content of folder "FORD CODE CALCULATOR" to the installed patch : C:XXX TrueCode ,replace the old files.,then run the FordOBD.exe,the ford software is OK now.
4. copy the content of folder" renault nissan" to C:XXX TrueCode ,replace the old files. then run the "TrueCode.exe",the renault nissan software is OK now.
5.copy the content of folder "system32" to the windows system patch : C:\WINDOWS\system32
terminator1000 est déconnecté   Réponse avec citation
