Discussion: defap egr off evoque
Vieux 19/11/2016, 18h30
Kennfeld
Avatar de Kennfeld
Pouvoir de réputation: 27
Kennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud of
Version details
Date Version * Change
08.07.2016 2.78 New Timeout for extended calculation increased
16.06.2016 2.77 Fixed Extended calculation was slow
08.06.2016 2.76 Fixed Couldn't be loaded on some systems
23.12.2015 2.75 Fixed ME17.8.3 was recognized as EDC17
21.12.2015 2.74 Fixed Possible problem fixed
15.10.2015 2.73 Fixed Possible Crash fixed
14.10.2015 2.72 New Check of extended RSA calculation improved
20.08.2015 2.71 New Now with EEprom checksum correction
07.07.2015 2.70 New Recognition of truck files improved
15.05.2015 2.69 Fixed Crash fixed
15.05.2015 2.68 Fixed Sometimes the RSA CS was not recognized as corrected
13.05.2015 2.67 Fixed Crashes on some computers fixed
21.04.2015 2.66 New Now file size up to 8MB; Sometimes the readout protection could not be placed
20.04.2015 2.65 Fixed At one file the key was not detected
18.04.2015 2.64 New Truck support improved
17.04.2015 2.63 New New Ford file
03.04.2015 2.62 Fixed A checksum block was not recognized which is outside a data block
27.03.2015 2.61 New Always insert virtual elements: Maps are always in element -data-
28.01.2015 2.60 New New Ford Focus file
30.12.2014 2.59 Fixed Crash at some files
24.12.2014 2.58 New Speed improved at checksum block search
05.12.2014 2.57 New Improved handling of Processor2 and Eprom2 elements
19.09.2014 2.55 New Search area for additional checksum enlarged
20.08.2014 2.54 Fixed Leave away compatibility test checksum, if referenced area doesnt contain useful data
08.08.2014 2.53 New Recognition of an already corrected file as original improved
02.07.2014 2.52 New Search routine for additional CS improved
03.06.2014 2.51 New Ford-CS: Area extended
27.05.2014 2.50 New Extended RSA calculation now leaves one core free so that the computer keeps usable.
14.04.2014 2.49 New New Ford file
26.03.2014 2.48 Fixed Correction at Ford-CS
22.03.2014 2.47 Fixed Error at placement of the patch tag block
15.03.2014 2.46 New Additional Ford CS at more files implemented
15.10.2013 2.45 New Additional checksum at Ford Focus
10.08.2013 2.44 Fixed Readout protection address modified at Ford Focus ST
08.08.2013 2.43 New New file
18.02.2013 2.42 Fixed Problem at Hyundai Veracruz
17.01.2013 2.41 Fixed Problem with compiler setting
21.12.2012 2.40 Fixed Maximum number of checksum blocks in a data block increased
29.08.2012 2.39 Fixed RSA key not found in Nissan EDC17C42
25.07.2012 2.38 Fixed Differentiation between MED17 and EDC17 now on favor to MED17
Kennfeld est déconnecté   Réponse avec citation
