Vieux 30/11/2016, 21h15
fenril68
Avatar de fenril68
Pouvoir de réputation: 45
fenril68 has a reputation beyond reputefenril68 has a reputation beyond reputefenril68 has a reputation beyond reputefenril68 has a reputation beyond reputefenril68 has a reputation beyond reputefenril68 has a reputation beyond reputefenril68 has a reputation beyond reputefenril68 has a reputation beyond reputefenril68 has a reputation beyond reputefenril68 has a reputation beyond reputefenril68 has a reputation beyond repute
Par défaut fly fvdi reçu mais probleme d'installation
Salut les amis j'ai reçu mon fly fvdi 2014 mais le probleme c'est que je n'arrive pas l'installer correctement.
a chaque fois que je l'ouvre j'ai le soft qui m'indique ceci :
CANNOT SET AVDI FTDI LATENCY TIMER
probably you don't have administrative rights
Without this setting the AVDI cannot work normally
Normally you can set the latency time with administrative privileges
from ControlPanel\Systeme\device manager\Ports,then double-click over the Com-port where the AVDI is recognized,then Port settings\Advanced and Latency timer should be set to 1 ms
je précise que j'ai telecharger la version a seedoo mais meme celle ci ne change pas .
DANS LE 2 VERSIONS LE SOFT BMW ET MINI NE S OUVRE PAS
LES AUTRES S'OUVRENT APRES LE MESSAGE CI-DESSUS MAIS J'AI ESSAYER DE COMMUNIQUER AVEC MON VEHICULE RIEN NE SE PASSE ET ÉVIDEMMENT J'AI TOUJOURS LE MEME MESSAGE QUI S OUVRE MEME AVEC LE VEHICULE CONNECTE.
QUE FAIRE ??????
Le scorpion pique celui qui l'aide à sortir du feu.... Un thank's au passage les amis ;-)
fenril68 est déconnecté   Réponse avec citation
The Following User Says Thank You to fenril68 For This Useful Post:
pp08 (26/01/2020)
