Vieux 30/11/2016, 21h45
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Par défaut Lexia & PP2000 updates (Up-to DiagBox v8.37)
The software provided and the procedures proposed are intended for personal, educational and experimental use to install DiagBox 8.xx related updates. I hold no responsibility for any illegal or improper usage. Carry out this procedure at your own risk.
I present 2 compilations "APP_Update_817-837.EXE" and "APP_Update_835-837.EXE" (links in the attachment). Those executables are intended to update Lexia and PP2000 from version 8.17+ or 8.35 respectively, to the latest 8.37 and will bring Lexia v500.74 and PP2000 v600.79 to latest fixes or support level.
APP_Update_817-837.EXE update should be attempted if you have a working DiagBox v8.17 / v7.81 installation or higher, or if you have a working "APP-835.7z" implementation.
APP_Update_835-837.EXE update should be attempted if you have a working "APP-835.7z" implementation.
Procedure:
1- Ensure you have a backup copy of the file "C:\AWRoot\bin\fi\APPDIAG.SYS" before you start.
2- Download and execute the appropriate file for your own setup. The process will copy all necessary files to the updt folder, it will then automatically kill all associated processes to enable overwriting without conflicts.
3- Run DiagBox to start the update process and wait until DiagBox is operational. Close DiagBox and restart your computer to ensure all processes are running.
Done..! you may run DiagBox as usual..
Have fun!
Lexia language is set to English and PP2000 to french, if you wish to change them, edit the DICO.TXT file in the EXE folders of LEXIA or OUTILREP (PP2000) and replace "GB" with "FR" or vise versa.
P.S. DiagBox has been running on Firmware 4.3.4 since 7.66/8.02.
Regards, Simple.
Type de fichier : txt APP-Update_817+835-817.txt (1,3 Ko, 416 affichages)
Simple est déconnecté   Réponse avec citation
The Following 12 Users Say Thank You to Simple For This Useful Post:
AKDAN (14/01/2018), autodiagauto (29/11/2018), bzkmatrix (02/03/2019), ElTurco (29/11/2018), JOE (07/12/2016), kevin22 (11/08/2017), meraakk (08/01/2022), PRODIAG75 (15/01/2022), prt93 (28/12/2019), rickymix (16/09/2017), Roturbo (03/06/2018), supernaturel.sportman (06/12/2017)
