Discussion: Code radio VW
Vieux 11/12/2016, 20h03
hamed
Avatar de hamed
hamed is on a distinguished road
Salem 3alikoum Wa Rahmatou Lah ou Barakatou .
pour avoir code les deux premier chifre il faux suivre le pdf joig.
pour avoir code complé lire mcu voila aimicalement.
**First Save safe,place original dump 95128!!!**
-After modify memory dump areas AE0 .... CD0 in FF and to write memory 95128,
-Power on the radio(on this moment MCU D70F3358 write new values on adress B50 and B54)
-Again the memory is read new.
-Notice,that addresses initial B50 and B54 appear some value.This values is used in algo.
-First 2 digits,is calculated by the formula:.
B50 xor AE0 = first digit
B54 xor AE1 = second digit code.
Example 96 xor 96 = 0 First digit.
10 xor 98 = 88 Second digit and first 2 digits is 09** ( digit 8 is 9)
AE0 and AE1 is original values located in original dump!!
And more : On rezults digit 8 is in reality 9 ,and 9 is reality 8. (8=9,and 9=8)
Example :
09xx reality is 08xx first 2 digits is 08**
08xx reality is 09xx first 2 digits is 09**
Digits 0…7 remain real values.
EXAMPLE : This is, original bin file.
Modification file on FF address area ae0 …cd0
New file read after radio is power on.
hamed est déconnecté   Réponse avec citation
