Vieux 23/01/2017, 01h20
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
Hello,
I think your problem is due to the fact that you have not edited the version statement from 8.xx to 7.xx in the file VERSION.INI. You probably have version=8.17.
Navigate to "C:\AWRoot\bin\fi\" and edit the file "version.ini" such that it reads:
[APPLICATION]
Version=07.817
Save and exit and try again..
I like the last 3 digits to indicate which DiagBox I am really running. For example, if I am running DiagBox v8.38, then my version.ini will have the lines:
[APPLICATION]
Version=07.838
This allows Lexia and PP2000 to run flawlessly and reflects the proper software version.
Good luck.
Simple est déconnecté   Réponse avec citation
