Vieux 24/01/2017, 20h27
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
You are saying that you had DiagBox 8.17 installed, is Lexia working or is it also disabled?
- Did you install start with DiagBox 7.01/02 then updated to 7.57 or what?
- Was DiagBox 7.xx working?
- Did you install DiagBox 8 in accordance with the procedure?
- Do you have .Net 3.51 and VC++ 2008 installed?
- Were DiagBox 8.01 and Lexia + PP2000 working?
Can you explain what did you install and what was working? and at what stage things go wrong?
Simple est déconnecté   Réponse avec citation
