Vieux 25/01/2017, 00h11
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
I forgot to say that before you start DiagBox, navigate to "C:\AWRoot\dtwr\updt\" and delete all contents of the updt folder. Otherwise, it will attempt to update the failed updates that you tried earlier.
When you run Kill_DiagBox_Tasks.bat run it as Administrator, also run DiagBox as Administrator and make sure that your network is disconnected.
P.S. Try PP2000 and Lexia after installing APP-835 (you don't need to connect to a car, try manually a111111111111111 as VIN and 11111 as RPO).
Simple est déconnecté   Réponse avec citation
