Vieux 31/01/2017, 00h37
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
The solution to this problem was as expected from the beginning, removing or commenting "version=08.xx" in "version.ini" and setting it to "version=07.xx" resolves the issue with Lexia and PP2000, like this:
[APPLICATION]
Version=07.817
This is explained in the DiagBox 8.01 Installation (updated) thread under Versions.
However, there is an interesting point here. When the option "Hide extensions for known file types" in the File Manager menu is checked, then file extensions do not show. In this case the user may be editing a file named "version.ini.txt" which will not work.
Hence, ensure that the option "Hide extensions for known file types" is unchecked so that you see file extensions.
Simple est déconnecté   Réponse avec citation
