Vieux 02/02/2017, 01h10
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
The version reflected in your DiagBox is in C:\AWRoot\bin\fi\version.ini, which is not changed by this update. If you wish to change it, edit it manually to read:
[APPLICATION]
Version=07.835
I don't know why did it go wrong for you after 8.35, I hope you will be successful next time. but make sure your network connection is disabled.
Good luck, Simple.
Simple est déconnecté   Réponse avec citation
