Vieux 16/12/2008, 14h57
didi_du_93000
Avatar de didi_du_93000
Pouvoir de réputation: 25
didi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to beholddidi_du_93000 is a splendid one to behold
Envoyé par Tlemcen-Electronic Voir le message
You can remove the old eprom from the old dash then solder it in the new one and the car will start ;)
If i turn off the immo on the ecu. the car turn on with the new dashboard?
On this dashborad the km is on the 68HC912. But the pin i don't know if it's on the same processour or no.
You know where is the pin and if is it possible for change this pin?
didi_du_93000 est déconnecté   Réponse avec citation
