Vieux 26/02/2017, 23h38
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
For Lexia and PP2000 to work, version needs to be 07.xxx and NOT 08.xxx. Use this standard [version=07.Update#]. So after update 8.02 --> set version=07.802 and after 8.10 --> version=07.810 etc.
Basically, after the update and before starting DiagBox, set the "version.ini" file to :
[APPLICATION]
version=07.817
You can keep the version # the same (07.817) with all updates if you wish, it will work fine regardless..
Now, set the language of your choice through the menu while you are at update 8.02. Otherwise it will not be possible through the menu if you install later updates, and you will have to edit some other files.
Simple est déconnecté   Réponse avec citation
The Following 3 Users Say Thank You to Simple For This Useful Post:
kilm (02/03/2018), Walid25 (07/04/2019), Y.B tec (01/03/2018)
