Vieux 04/03/2017, 19h51
Simple
Avatar de Simple
Pouvoir de réputation: 22
Simple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud ofSimple has much to be proud of
DiagBox v7 final release was v7.77, and DiagBox v8.01 corresponds with v7.65, you can find this information here:
http://service.citroen.com/dtt/IFD/AC/documents/fr_FR/
But DiagBox 8 had newer engines (probably to enable new functions and remote services which will be introduced later). Another change was at 7.72/8.08, where the locale coding standard was changed from 2 chr$ to 5. This is why changing language from the menu does not work, I have explained this in one of the posts last year.
DiagBox 7.83 corresponds to 8.19, which I released for DiagBox 7 last year. But in the case of DiagBox 8, I stopped at 8.17 because this is the level where I could use the full ******* updates without removing anything from the original files. The same applies to the APP_8.17-8.42 updates, they are all full updates with nothing removed.
If you install 8.01 and update 8.02 and I think up to 8.10 (as far as I remember), you can use (relevant) maitresox updates to reach 7.83/8.19. Because all updates from 7.67/8.03 are ******ly identical.
Simple est déconnecté   Réponse avec citation
