Vieux 27/03/2017, 16h06
davidhofff
Avatar de davidhofff
davidhofff will become famous soon enough
ecu testé mais il en prend d'autres.
BMW 120d 2009 edc17cp02 egr off (OK)
Peugeot P406 edc15c2 egr off (OK)
Peugeot P407 edc16c34 egr off (OK)
Golf 6 PCR 2.1 egr off (OK)
Passat B6 EDC17CP20 dpf off (OK)
Citroen c4 1.6 hdi edc16c34 egr off (wrong solution)must use Peugeot (Solution 2)
Ford Galaxy 2.0 tdci SID206 egr off (OK)
Clio 1.5dci egr off (OK)
audi A3 with pcr 2.1 for dpf (ok)
suzuki 1.9 dpf (ok)
peugeot edc17c10 dpf (ok)
Audi a4 2.0 tdi edc16u31 egr off (ok)
peugeot 308 edc16c34 dpf (ok)
volvo s60 edc16c34 version switch (ok)
Denso Mitsubishi DPF - Processor 7058 and 7059 (OK)
Alfa 159 edc16c39 egr (OK)
Opel Zafira edc16c39 dpf (OK)
MB E320 w211 EDC16C2 DPF Type 1 don't work Type 2 DPF OFF ok.
Opel vivaro 1.9dci EDC15C2 Egr off ok with disconnected egr plug.
EDC15C2 with Citroen Dpf remove solution - ecusafeV2 with citroen solution is OK.
vw ppd1 dpf ok,
benz edc 16cp31 dpf ok,
vw edc 16u1 egr ok, pcr2.1 dpf ok.
pcr 2.1 egr ok.
fiat/opel edc16c3 and
edc16c39 dpf ok
635d with edc16cp35 and works Very good with dtc off.
mazda 3 EDC16C34 - with ecu 0281011995 (OK)
mazda 3 2007 1.6d edc16c34 dpf solution -(OK)
Audi A4 EDC17CP14 DPF Off
Audi Q7 EDC16CP34 DPF Off
VW Touareg EDC16CP34 V6 DPF Off
Renault Scenic EDC16C3 V1 DPF Off (How to know the version you need ? )
BMW 320D EDC16C35 DPF Off
BMW EDC16C35 DPF EGR OK
PEUGEOT DELPHI DCM3.5 DPF OK
AUDI A1 SIMOS PCR 2.1 EGR DPF OK
mazda5 2006 2,0 81kW DENSO dpf (OK)
renault edc16C03/9 DPF OK
WV Transporter 2006 2,5 96kW EDC16U34 DPF Generic Switch (OK)
marelli mjd8f2 - OK
Opel Vectra 1,9DTi 16c39 dpf off= (OK)
Ford S-Max 2007 SID 206 EGR off= OK
Fiat 500 mjd8f2 DPF OK delete sensor
Fiat 500 mjd8f2 EGR OK
Fiat Bravo 2008 EDC16C39 EGR OK
307 SID 803 DPF ok with solution 803A
EGR Vectra edc16 - one switch OK
audi A4 2,0 edc 16u31 dpf off=OK
caddy 1.9 edc 16u34 egr/dpf off=ok
caddy 1.6 simos pcr 2.1 egr/dpf off=ok
Hyundai Santa Fe 2008 edc16c39
EGR OFF P0489 EGR Disconnect ---- delete ok
DPF OFF error P2002 P0473 --- delete OK
pcr2.1 egr done ok
zafiza edc16c9 dpf ok
Ford Galaxy 2008 SID206 DPF/EGR= OK
davidhofff est déconnecté   Réponse avec citation
