Discussion: Immo off EDC16C3
Vieux 23/04/2017, 17h13
Kennfeld
Avatar de Kennfeld
Pouvoir de réputation: 26
Kennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud ofKennfeld has much to be proud of
Envoyé par AOUN Voir le message
Virgin won't help. Key working but sometimes cannot start. Customer's request need remove...
The below is instruction. It's not mine but from other forum so it is definetely works. Don't have lexia yet so cannot check.
Preparation with PP2000:
0. Go to replacement parts->injection->injectors-> print screen the injector codes
0.5 Go to engine ecu->configuration -> print screen the configuration
The cooking recipe:
1. Read eeprom with BDM (2kb size!)
2. Make virgin with ImmoDec 3.2
3. Disable immo on the virgin file with Immo tool v1.5
4. Load the eeprom file with BDM
5. With PP2000 go to ecu->confiuguration (notice all settings are virgin), do the correct configuration
6. Go to replacement parts->Injection->injectors , register the injector codes
Hi on this forum we dont need immo dec 3.2 or other software we know to decode and code directly in bin when you use bdm no need of any tools juste hexeditor and brain so no need of cracked diagbox or pps2000
see prévious message for decoder ;)
Type de fichier : jpg injecteurcoding-olsFR.JPG (24,0 Ko, 59 affichages)
Type de fichier : jpg injecteur1configmap-olsFR.JPG (47,1 Ko, 62 affichages)
Kennfeld est déconnecté   Réponse avec citation
