Discussion: Un peu perdu
Vieux 23/04/2017, 23h43
kdo75
Avatar de kdo75
Pouvoir de réputation: 24
kdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud ofkdo75 has much to be proud of
Envoyé par jah83 Voir le message
j ai donc tout installer, rhiengold se lance bien par contre je n ai pas de communication.
J ai erreur NET-0015: HOST NOT FOUND
surement la config pour mon cable K+Dcan
Ci joint mon fichier ediabas. ini si quelqu un voit quelques choses qui clocherait.
;# EDIABAS 7.3.0 #
[Configuration]
Interface =STD:OBD
Simulation = 0
EcuPath =C:\EDIABAS\ECU
SimulationPath =C:\EDIABAS\SIM
TracePath =C:\EDIABAS\TRACE
TraceSize = 1024
ApiTrace = 0
IfhTrace = 0
; IfhnTrace = 0
; SystemTraceSys = 0
; SystemTraceBip = 0
; SystemTraceIfh = 0
; SystemTraceNet = 0
; BipDebugLevel = 0
; BipErrorLevel = 0
UbattHandling = 0
IgnitionHandling = 0
ClampHandling = 0
RetryComm = 1
SystemResults = 1
TaskPriority = 0
; CodeMapping = C:\EC-Apps\EDIABAS\BIN\ansi2oem.tab
; LoadWin32 = 0
NetworkProtocol = TCP
; --- neu ab EDIABAS 7.2.0 ---------------------------------------------------
ShowIcon = 1
LogLevel = 0
TraceBuffering = 0
TraceHistory = 0
TraceSync = 1
; TraceWriter = <FilePathName>
[TCP]
RemoteHost = LMUC203404
Port = 6801
TimeoutConnect = 2000
TimeoutReceive = 2000
TimeoutFunction = 10000
; TimeResponsePending = 5000
; DisconnectOnApiEnd = 1
; InitCmd0 = FE,04,00,03,01
; InitCmd1 = FD,05,00,03,01
[XEthernet]
RemoteHost = Autodetect
HeaderFormat = 0
TesterAddress = F4,F5
TimeoutConnect = 20000
[IfhProxy]
Port = 6700
;## ausführliche Variante von EDIABAS.ini (mit Kurz-Info und Default) ##
; EDIABAS Basic Configuration
; [Configuration]
;### new Configuration elements since EDIABAS 7.2 ############################
; ShowIcon
; Description : Enable/Disable EDIABAS-Icon in System-Tray
; Value : 0 = EDIABAS-Icon disabled
; 1 = EDIABAS-Icon enabled
; Default = 1
; ShowIcon = 1
; LogLevel
; Description : Logging of fatal faults in EDIABAS.log
; Value : 0 = Logging disabled
; 1 = Logging enabled
; Default = 0
; LogLevel = 0
; TraceBuffering
; Description : Manner of Opening/Closing of Trace-Files
; Value : 0 = Opening/Closing after every dump
; 1 = Trace-Files stay open
; Default = 0
; TraceBuffering = 0
; TraceHistory
; Description : Number of History-Trace-Files
; Value : 0 .. 999
; Default = 0
; TraceHistory = 0
; TraceSync
; Description : Synchronisation of Trace files
; Value : 0 = Synchronisation disabled
; 1 = Synchronisation enabled
; Default = 1
; TraceSync = 1
; TraceWriter
; Description : FilePathName of a private TraceWriter
; Default = . (Default-TraceWriter "TWFile32.dll")
; TraceWriter = .
;### older Configuration elements till EDIABAS 7.1 ###########################
; Simulation
; Description : Enable/Disable ECU simulation
; Value : 0 = Simulation disabled
; 1 = Simulation enabled
; Default = 0
; Simulation = 0
; EcuPath
; Description : ECU file path
; Default = .
; EcuPath = C:\EC-Apps\EDIABAS\ECU
; SimulationPath
; Description : Simulation file path
; Default = .
; SimulationPath = C:\EC-Apps\EDIABAS\SIM
; TracePath
; Description : Trace file path
; Default = .
; TracePath = C:\EC-Apps\EDIABAS\TRACE
; TraceSize
; Description : Maximum size of each trace file [KB]
; Value : 0 .. 32767
; Default = 1024
; TraceSize = 1024
; ApiTrace
; Description : Enable/Disable API/User trace
; Value : 0 = Trace disabled
; 1 = User trace
; 2 = User trace + time stamp
; 3 = User trace + time stamp + process id (Win32)
; 4 = Function trace
; 5 = Function trace + time stamp
; 6 = Function trace + time stamp + timing
; 7 = Function trace + time stamp + timing + process id (Win32)
; 8 = Debug trace
; Default = 0
; ApiTrace = 0
; IfhTrace
; Description : Enable/Disable IFH trace
; 1 = User trace
; 2 = User trace + interface
; 3 = User trace + interface + time stamp
; Default = 0
; IfhTrace = 0
; IfhnTrace
; Description : Enable/Disable IFH network trace (with XREMOTE)
; 1 = User trace
; Default = 0
; IfhnTrace = 0
; SystemTraceSys
; Description : Enable/Disable system trace (runtime system)
; Trace levels 1 .. 7
; Default = 0
; SystemTraceBip
; Description : Enable/Disable BIP trace (runtime system)
; Default = 0
; SystemTraceIfh
; Description : Enable/Disable IFH system trace
; Default = 0
; SystemTraceNet
; Description : Enable/Disable network trace
; Default = 0
; BipDebugLevel
; Description : BIP debug level of ECU files
; Default = 0
; BipDebugLevel = 0
; BipErrorLevel
; Description : BIP error level of ECU files
; Default = 0
; BipErrorLevel = 0
; UbattHandling
; Description : Ubatt ON/OFF handling
; Value : 0 = Ubatt ON/OFF: No EDIABAS error
; 1 = Ubatt ON/OFF: EDIABAS error
; Default = 1
; UbattHandling = 0
; IgnitionHandling
; Description : Ignition ON/OFF handling
; Value : 0 = Ignition ON/OFF: No EDIABAS error
; 1 = Ignition ON/OFF: EDIABAS error
; Default = 1
; IgnitionHandling = 0
; ClampHandling
; Description : automatic check of clamps for Ubatt and Ignition
; Value : 0 = no automatic clamp check with send_and_receive
; 1 = automatic clamp check with send_and_receive
; Default = 1
; ClampHandling = 1
; RetryComm
; Description : Repeat failed communication automatically (1x)
; Value : 0 = Retry disabled
; 1 = Retry enabled (1x)
; Default = 1
; RetryComm = 1
; SystemResults
; Description : Enable/Disable system results (ubatt/ignition/jobstatus)
; Value : 0 = Disable system results
; 1 = Enable system results
; Default = 1
; SystemResults = 1
; TaskPriority
; Description : EDIABAS process/thread priority (only Win32/16)
; Value : 0 = Optimal EDIABAS performance = 8
; 1 = Minimal EDIABAS performance
; 10 = Maximal EDIABAS performance
; Default = 0
; TaskPriority = 0
; CodeMapping
; Description : Character mapping file path
; Default = .
; LoadWin32
; Description : Map EDIABAS Win16 calls to EDIABAS Win32
; Value : 0 = Win16/32 Mapping disabled (Win16-->Win16)
; 1 = Win16/32 Mapping enabled (Win16-->Win32)
; Default = 0 for Windows 9x/Me
; Default = 1 for Windows NT4/2000/XP
; LoadWin32 = 0
; NetworkProtocol
; Description : Network protocol
; Default =
; NetworkProtocol = TCP
; Interface
; Description : Connected diagnosis interface
; Default = EDIC
; Interface = STD:FUNK
; Additional information (in German) :
; Bitte beachten: Der HW-Treiber fuer das Interface muss installiert sein!
; Beschreibung : Funk-Diagnose Interface MDA von Fa. Siemens
; Installation : keine
; INI-Datei : FUNK.INI
; Ansprechpartner: Manuel.Rothenberger@bmw.de
; WINDOWS-Freig. : WIN NT 4.0 : Ja
; WIN XP 32-Bit : Ja
; WIN 7 32-Bit : Ja
; Interface = STD:OMITEC
; Beschreibung : Nachfolger von OBD / enthält CAN-Anbindung / Anschluss an OBD-Dose
; Installation : \EDIABAS\HARDWARE\OMITEC\AnleitungfuerOMITECInstal lation.pdf
; INI-Datei : siehe \EDIABAS\HARDWARE\OMITEC\Omitec_Doku.pdf
; Ansprechpartner: Reinhold.Drexel@bmw.de
; WINDOWS-Freig. : siehe \EDIABAS\HARDWARE\OMITEC\Omitec_Doku.pdf
; Interface = STD:OBD
; Beschreibung : Serieller Pegelwandler (Nachfolger von ADS / Anschluss an OBD-Dose)
; Installation : \EDIABAS\HARDWARE\OBD\ODBSETUP (nur noetig fuer WIN NT4, WIN 2000, WIN XP)
; INI-Datei : siehe \EDIABAS\HARDWARE\OBD\OBD_DOKU.pdf
; WIN 7 32-Bit : Ja
; Interface = EDIC
; Beschreibung : Anbindung über K-Line
; HW-Derivate : PC-Card, PCMCIA , W-LAN (Interface von Fa. Softing)
; Installation : \EDIABAS\HARDWARE\EDIC\SETUP.EXE
; INI-Datei : EDICFW.INI, EDICHW.INI
; Ansprechpartner
; * EDIC-PC : Gerd.Huber@bmw.de
; * PCMCIA : Gerd.Huber@bmw.de
; * EDIC-NET : (Richard.Kolbeck@bmw.de)
; WIN 7 32-Bit : Ja
; Interface = EDICC
; INI-Datei : EDICFW.INI, EDICHW.INI, XEDICC.INI
; Ansprechpartner
; WIN 7 32-Bit : Ja
; Interface = STD:CAN
; Beschreibung : PCMCIA CAN-Interface CanCardX von Fa. Vector
; Installation : keine (ausser Installation der CAN-Karte)
; INI-Datei : CAN32.INI
; Ansprechpartner: FLASH.SERVICE@BMW.DE (Hotline)
; WINDOWS-Freig. : !nicht mehr im Paket enthalten!
; Interface = REMOTE
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP (für Normalbetrieb)
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port)
; INI-Datei : keine
; Ansprechpartner
; * Remote-PC : Gerd.Huber@bmw.de => Referenz@bmw.de
; * OP(P)S : Michael.Rowedder@bmw.de
; * ICOM,Fertig. : ! keine Verwendung !
; * ICOM,Vertrieb: Robert.Schwinn@bmw.de
; WIN 7 32-Bit : Ja
; Interface = REMOTE:name
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP (für Parallelbetrieb)
; INI-Datei : REMOTE.INI (insbesondere für Parallelbetrieb notwendig)
; In REMOTE.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port).
; Ansprechpartner
; * Remote-PC : ! momentan keine Verwendung !
; WIN 7 32-Bit : Ja
; Interface = RPLUS
; Beschreibung : Anbindung eines EDIABAS-Interfaces über TCP/IP (für PROXY-Betrieb)
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (insb.: RemoteHost, Port)
; INI-Datei : keine
; Ansprechpartner
; * Remote-PC : ! keine Verwendung !
; * OP(P)S : ! momentan keine Verwendung !
; * ICOM,Fertig. : Manuel.Rothenberger@bmw.de
; * ICOM,Vertrieb: ! momentan keine Verwendung !
; WIN 7 32-Bit : Ja
; Interface = RPLUS:name (z.B.:RPLUS:ICOM_P)
; Beschreibung : Anbindung des EDIABAS-Interfaces ICOM über TCP/IP
; Installation : Anpassung der Einträge in [TCP] auf beiden Seiten (ins.: RemoteHost, Port) in den INI-Dateien
; INI-Datei : RPLUS.INI (Nutzung im Zusammenhang mit dem Interface ICOM)
; In RPLUS.INI stehen unter [name] spezif. Einstellungen(z.B.: RemoteHost, Port).
; Ansprechpartner
; WIN 7 32-Bit : Ja
; Interface = ENET
; Beschreibung : Anbindung über Ethernet
; Installation : Anpassung der Einträge in [XEthernet] (insb.: RemoteHost)
; INI-Datei : ENET.INI (insbesondere für Parallelbetrieb notwendig)
; Ansprechpartner: Gerd.Huber@bmw.de => Referenz@bmw.de
; WINDOWS-Freig. : WIN NT 4.0 : Nein
; WIN 7 32-Bit : Ja
; WIN 7 64-Bit : Ja
; Interface = PROXY:<Interface>
; z.B. Interface = PROXY:STD:FUNK
; z.B. Interface = PROXY:ENET
; Beschreibung : EDIABAS wird im PROXY-Modus betrieben
; Installation : hängt vom benutzten Interface ab
; INI-Datei : hängt vom benutzten Interface ab
; Ansprechparter : Gerd.Huber@bmw.de => Referenz@bmw.de
; WIN 7 32-Bit : Ja
; Konfigurationslemente, die existieren,
; aber nicht in EDIABAS.ini geändert werden können
; BipEcuFile
; Description : Dateititel der aktuell geladenen SGBD
; (nur gültig während einer Job-Verarbeitung)
; Value : String
; Default = -
; EdiabasIniPath
; Description : Pfad der verwendeten EDIABAS.ini
; Value : String
; Default = -
; EdiabasVersion
; Description : verwendete EDIABAS-Version
; Value : String
; Default = -
; IfhVersion
; Description : verwendete IFH-Version
; Value : String
; Default = -
; Session
; Description : Name der EDIABAS-Session
; Value : String
; Default = -
; TCP/IP Configuration
; [TCP]
; RemoteHost
; Description : server address/name
; Default = -
; RemoteHost = LMUC203404
; Port
; Description : IP communication port
; Value : 1000 < port < 30000
; Spezialfall OP(P)S / ICOM:
; Value : 6801 ;OBD-Treiber (CAN)
; Value : 6802 ;Most-Treiber
; Default = -
; Port = 3000
; weitere Details siehe Dokumentationen
; TimeoutConnect
; Description : Timeout for establishing the connection
; Value : 1000 ... 59000
; Default = 5000
; TimeoutConnect = 2000
; TimeoutReceive
; Description : Timeout for receiving a message
; Default = 5000
; TimeoutReceive = 2000
; TimeoutFunction
; Description : Timeout for a long function
; Value : 5000 ... 59000
; Default = 59000
; TimeoutFunction = 10000
; Description : Time between alive-messages
; Value : 500 ... 59000
; Default = 2000
; Description : Enable/Disable Disconnection with function call ApiEnd
; Value : 0 = Disconnection disabled
; 1 = Disconnection enabled
; Default = 0
; InitCmd<n>
; Description : Initialization command <n> (normally for OPPS)
; Default =
; XETHERNET Configuration
; [XEthernet]
; RemoteHost
; Value : Autodetect
; 169.254.1.1 ; Beispiel
; 192.168.100.1 ; Beispiel
; Default =
; RemoteHost = Autodetect
; IfhRemoteHost
; Default =
; IfhRemoteHost = Autodetect
; HeaderFormat
; Description : type of header
; Value : 0 ; 6Byte Header (B-Muster)
; 1 ; 3Byte Header (A-Muster)
; Default = 0
; HeaderFormat = 0
; TesterAddress
; Description : list of permitted tester adresses
; Value : F4 ; F1 durch F4 ersetzen
; F5 ; F1 durch F5 ersetzen
; F4,F5 ; F1 zuerst durch F4 ersetzen, dann F1 durch F5 ersetzen
; F5,F4 ; F1 zuerst durch F5 ersetzen, dann F1 durch F4 ersetzen
; Default = -
; TesterAddress = F4,F5
; ControlPort
; Description : port of control channel of TCP connection to ZGW
; Value : 1000 < port < 59000
; Default = 6811
; ControlPort = 6811
; DiagnosticPort
; Description : port of diagnostic channel of TCP connection to ZGW
; Default = 6801
; DiagnosticPort = 6801
; TimeoutConnect
; Description : timeout in ms for connection to ZGW
; Default = 20000
; TimeoutConnect = 20000
; XPROXY Configuration
; [IfhProxy]
; Port
; Description : IP base proxy port
; Ports : +0 = unknown interface
; +1 = EDIC
; +2 = EDICC
; +3 = ENET
; +4 = STD
; +5 = REMOT
; Default = 6700
; Port = 6700
; End Of File EDIABAS.ini
bonsoir Jah83
as tu verifier dans le fichier
C/ediabas/bin/obd.ini
au debut tu trouve sa :
Port=Com9
Hardware=USB
RETRY=ON
;Tracelevel=0xFFFFFFFF
;Tracelevel=0xF0000000
;Tracelevel=0x0000FFFF
; Bit 0 = Funktionsaufruf
; Bit 1 = io Ergebnis
; Bit 2 = nio Ergebnis
; Bit 3 = Detailinfos
; Nibble 0 = readchar_wait
; Nibble 1 = main
; Nibble 2 = cmd
; Nibble 3 = obd
; Nibble 4 = send_and_receive_...
; Nibble 5 = read_telegram_...
; Nibble 6 = send_telegram
; Nibble 7 = SendDat
kdo75 est déconnecté   Réponse avec citation
