Discussion: probleme xentry / das
Vieux 04/07/2017, 03h29
yanos57
Avatar de yanos57
yanos57 is an unknown quantity at this point
c'est une smart roadster , le calculateur ne fonctionne pas comme ca , voila l'annonce du vendeur du calculateur:
This ECU has the SB2 software installed, the software is fully working with no safe mode problems.
The ECU will need programming to the car with a ‘MB star’ (code the keys and clutch teach).
OR
After perchance you can send your ECU with tracked delivery to the address provided.
I can clone your on to this ECU. The ECU would then be ready to be installed in the car and no further coding is needed with a ‘MB star’.
The ‘BRABUS SB2’ was power upgrade offered by Smart for the standard 80 bhp Smart Roadster (non- BRABUS). The ‘BRABUS SB2’ kit was made up from an updated ECU and a BRABUS TIK 74kw pipe.
With the updated ECU and a BRABUS TIK 74kw (or even better a Silicone Intake Hose) makes the standard 80 bhp Smart Roadster have a very simpler performance to a full BRABUS Roadster.
yanos57 est déconnecté   Réponse avec citation
